[WIP] Sailfish OS Alpha
(Yesterday, 02:11 PM)andybleaden@gmail.com Wrote: Well
Bluetooth to headphones didn't work
Nor to a speaker
Sound is now persistent
Apps Vs browser confirmation like with Twitter is bust
Could do with landscape mode but terminal landscape works!
Questions are
How to field bugs
Post solutions
Upgrade
How close is pinephone development to pinetab?
The situation is improving rapidly upstream. Adam Pigg has made some improvements to the builds and you're able to build it now from the flash-it script once again.
I'll ask where we'd like to have it filed best and will update later on.
File away here https://github.com/sailfish-on-dontbeevi...tab/issues
I was wondering how the best way would be to update any of the changes you make upstream?
Also quick question - I am really enjoying using this. Feels good and promising after a few days
Few issues (as we know BT/Keyboard etc) BUT
If I wanted to stick this on the EMMC - would I do this using jumpdrive do you think? (all my own risk etc etc )
(2 hours ago)andybleaden@gmail.com Wrote: I was wondering how the best way would be to update any of the changes you make upstream?
You may get some of the updates with a
zypper update
Jumpdrive should do fine. The current version doesn't display anything on the tab, but it should be visible on your PC.
