September release
#41
Like some others here I am getting stuck after the orientation on a black screen with the spinning blue wheel. Reboot or other and it is still stuck at the spinning wheel. I can pull down from the top to see indicators, I can pull up from bottom to start the camera app. But otherwise nothing!
As a clue, I think it is waiting to unlock since when I tried to go into some of the indicator settings it said I needed to unlock first. (but I can't get a keyboard to pop to enter the keycode).
Anyone else able to confirm? How can we get past what may be a lock screen issue? Possibly re-install can we NOT enter a passphrase?
(10-04-2020, 06:26 AM)rik-shaw Wrote: Like some others here I am getting stuck after the orientation on a black screen with the spinning blue wheel. Reboot or other and it is still stuck at the spinning wheel. I can pull down from the top to see indicators, I can pull up from bottom to start the camera app. But otherwise nothing!
As we have discussed in this thread: you have to insert a sim card -- it doesn't have to be a functional one. Good luck.
That... is... not... cool.
Bug as far as I'm concerned.
