08-31-2020, 03:57 PM
So I'm working on my darktable issue. I loaded LibreOffice writer and tried to select a font to see if it was actually installed, and the list was blank. When I highlight a font, it shows up the name highlighted and it can be selected, but the other unselected fonts in the list remain blank. I ran sudo fc-cache -vf and this is the output:
Font directories:
/usr/share/fonts
/usr/local/share/fonts
/root/.local/share/fonts
/root/.fonts
/usr/share/fonts/Roboto
/usr/share/fonts/TTF
/usr/share/fonts/adobe-source-code-pro
/usr/share/fonts/cantarell
/usr/share/fonts/encodings
/usr/share/fonts/gsfonts
/usr/share/fonts/noto
/usr/share/fonts/util
/usr/share/fonts/encodings/large
/usr/share/fonts: caching, new cache contents: 0 fonts, 8 dirs
/usr/share/fonts/Roboto: caching, new cache contents: 12 fonts, 0 dirs
/usr/share/fonts/TTF: caching, new cache contents: 36 fonts, 0 dirs
/usr/share/fonts/adobe-source-code-pro: caching, new cache contents: 30 fonts, 0 dirs
/usr/share/fonts/cantarell: caching, new cache contents: 11 fonts, 0 dirs
/usr/share/fonts/encodings: caching, new cache contents: 0 fonts, 1 dirs
/usr/share/fonts/encodings/large: caching, new cache contents: 0 fonts, 0 dirs
/usr/share/fonts/gsfonts: caching, new cache contents: 35 fonts, 0 dirs
/usr/share/fonts/noto: caching, new cache contents: 511 fonts, 0 dirs
/usr/share/fonts/util: caching, new cache contents: 0 fonts, 0 dirs
/usr/local/share/fonts: skipping, no such directory
/root/.local/share/fonts: skipping, no such directory
/root/.fonts: skipping, no such directory
/usr/share/fonts/Roboto: skipping, looped directory detected
/usr/share/fonts/TTF: skipping, looped directory detected
/usr/share/fonts/adobe-source-code-pro: skipping, looped directory detected
/usr/share/fonts/cantarell: skipping, looped directory detected
/usr/share/fonts/encodings: skipping, looped directory detected
/usr/share/fonts/gsfonts: skipping, looped directory detected
/usr/share/fonts/noto: skipping, looped directory detected
/usr/share/fonts/util: skipping, looped directory detected
/usr/share/fonts/encodings/large: skipping, looped directory detected
/var/cache/fontconfig: cleaning cache directory
/root/.cache/fontconfig: not cleaning non-existent cache directory
/root/.fontconfig: not cleaning non-existent cache directory
fc-cache: succeeded
Maybe an issue with looped directories?
Font directories:
/usr/share/fonts
/root/.fonts
fc-cache: succeeded
