New UBports edition - black screen (backlight) only
(08-04-2020, 11:13 AM)wibble Wrote: Have you tried booting a known stable image like Jumpdrive from the SD to rule out the software as the cause? https://wiki.pine64.org/index.php?title=..._Jumpdrive
What you're describing reminds me of what some people have reported with UBports after an unclean shutdown - it gets stuck when trying to mount one of the filesystems.  They've fixed it by booting another OS on the SD to run fsck on the eMMC filesystems, or to reinstall UBports or another OS on the eMMC. If you want to find out what's actually going on behind the blank screen you can use the headphone socket as a serial console.
I flashed Jumpdrive to a microSD card using "dd if=pine64-pinephone.img of=/dev/sdc bs=1M", inserted the SD card and booted the Pinephone. I get a green LED, then the screen backlight lights up but no image on the screen.
Is it safe to say I have a bad screen and need to file a RMA request?
You've ruled out the most obvious software based problem, so it's probably a good time to contact them. The serial terminal would tell you more if you have the required hardware. Beyond that you'd have to open it up - some people have found incorrectly seated connectors, and solved problems by reseating them - so in your position I'd want to get the OK from Pine64 first. They may have some other things for you to check before RMA.
Tongue Screen ghosting and omitting rows of pixels... bedtime 0 376 12-28-2023, 01:26 PM
Last Post: bedtime
  Replacement screen disconnects after back frame is screwed on robthebold 4 1,337 10-12-2023, 01:03 PM
Last Post: robthebold
  No calls on Pine Phone Beta convergence edition polypode 1 1,172 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  Screen dying already? marcih 153 145,444 02-23-2023, 04:14 AM
Last Post: Shatur
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 27 23,860 01-29-2023, 12:20 PM
Last Post: skandigraun
  BETA edition rcu errors 8bit 29 19,982 11-02-2022, 01:40 PM
Last Post: some_pinephone_user
  Screen Replacement Instructions erikkugel 4 3,148 09-07-2022, 11:04 PM
Last Post: RTP
  Severe screen flicker + occasional ghosting | Pinephone Beta edition legowave440 5 3,641 07-25-2022, 07:35 AM
Last Post: bedtime
  Double Image on screen Arvis 2 1,727 07-03-2022, 06:27 AM
Last Post: Avisando
Question Upgrading a 2020 Community Edition Pinephone? danimations 5 3,650 03-10-2022, 08:18 AM
Last Post: danimations
