My Daily Manual QA
I will be preforming some basic QA against the nightly build.
build image: mobian-pinephone-20200723.img.gz
I have limited my scope to what I consider requirements for a daily driver.  (SMS, 4G Calls, general sound quality, wifi, clock accuracy, etc. etc.)
Wifi: seems fairly stable after reboot. --------------------------------------------------------------------------------------------------------------------------------------------------- PASS
Boot time: Changed reboot from simple restart to battery out cold boot. (~ 1m 15s) ------------------------------------------------------------------------------------------ PASS
SMS in: Works as expected after cold boot --------------------------------------------------------------------------------------------------------------------------------------------- PASS
SMS out: Works as expected after cold boot ------------------------------------------------------------------------------------------------------------------------------------------- PASS
Calls out: Call connects, full audio, speaker works. ----------------------------------------------------------------------------------------------------------------------------------- PASS
Calls in: Connects. Call connects, full audio (iphone and android) ------------------------------------------------------------------------------------------------------------------ PASS
Camera front: Unable to figure out how to switch to front camera ----------------------------------------------------------------------------------------------------------------- FAIL
Camera back: Super Laggy ---------------------------------------------------------------------------------------------------------------------------------------------------------------- FAIL
Loud speaker:  opening video in web browser crashed the UI ---------------------------------------------------------------------------------------------------------------------- FAIL
Build stability: Unstable
Notes: Laggy interface on boot or application start. Firefox app crashed the desktop (not the phone). Camera, super laggy.
Results: Not a suitable candidate for daily driver.
Regarding the front camera: You can switch to the front camera by running:
pinephone-camera-setup.sh front
pinhole - the camera app - must not be running, else you get "Device or resource busy" errors.
To switch back to the rear camera, rerun the script without arguments.
Build image: mobian-pinephone-20200724.img.gz
Wifi: seems fairly stable after reboot. ----------------------------------------------------------------------------------------------------------------------------------------------------- PASS
Boot time: Changed reboot from simple restart to battery out cold boot. (~ 34s) ------------------------------------------------------------------------------------------- PASS
Calls in: Connects. Call connects, full audio (iphone and android) ---------------------------------------------------------------------------------------------------------------- PASS
Camera front: Image inverted, super pixelated, not sure if HW/SW--------------------------------------------------------------------------------------------------------------- FAIL
Camera back: Super Laggy, pixelated--------------------------------------------------------------------------------------------------------------------------------------------------------- FAIL
Loud speaker:  opening video in firefox played fine ------------------------------------------------------------------------------------------------------------------------------- PASS
Build stability: More stable than previous build. No UI crashes.
Notes: Caught an update right after fresh flash and first call test. Camera, super laggy.
Results: Not a suitable candidate for daily driver. Call quality is still lacking a little bit but shouldn't affect people with average hearing abilities.  Calls and texts appear to be solid outside of the minor clairty issue on the call. Call routing works correctly. Boot time is half of ubports.
Is this installed or from sd card ?
Are you using a UBPorts C.E. phone ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(07-24-2020, 06:23 PM)bcnaz Wrote: Is this installed or from sd card ?
UBPorts CE phone. Installed on sdcard. Since I am flashing the nightly builds I figure going through SD Cards is a better option than eMMC flashing daily. Also it is way easier to recover should something go awry.
I have made a change to the way I will be posting these results sets. I will be uploading a report every time I execute testing and will post a link (Maybe a screenshot if preferred.)
You can check https://tosstalk.com/pinephone/ for a list of the OSes I test.
report-2020-07-27
Conclusion: Not ready to be a daily driver.
Very good start to your project, however at the moment both links I clicked on led me to UBPorts July 27 reports.
(07-27-2020, 02:00 PM)bcnaz Wrote: Very good start to your project,  however at the moment both links I clicked on led me to UBPorts  July 27 reports.
Added a correction for that, also updated my template for clarity. Let me know if you see anything more. In the next week I plan on color coding pass and fails.
(07-27-2020, 01:35 PM)plainenough Wrote: I have made a change to the way I will be posting these results sets. I will be uploading a report every time I execute testing and will post a link (Maybe a screenshot if preferred.)
report-2020-07-27
Hey, thank you for doing this! I love it!
Conclusion: This OS is not ready for pinephone to be a daily driver.
NOTE: I have been running on nightly development builds. Most functionality appears to work correctly on this OS out of my testing groups it is the most mature candidate.
mobian/2020-07-28
  Debian / mobian Pine64 - User Manual? Harry27 1 5,971 03-03-2021, 04:50 PM
Last Post: LibrePhoneUser
  My Daily QA - 2020-10-06 AmazingNutria 6 12,542 01-05-2021, 10:08 PM
Last Post: daniel
  Why the 12/15/2020 build is no where near a daily driver yet TheLastDon 24 40,300 12-31-2020, 09:51 AM
Last Post: HLing
  My Daily QA - 2020-09-22 AmazingNutria 4 9,152 09-25-2020, 08:33 AM
Last Post: bcnaz
  My Daily QA - 2020-09-11 AmazingNutria 2 5,992 09-20-2020, 09:17 PM
Last Post: daniel
  My Daily QA - 2020-09-10 AmazingNutria 1 5,129 09-11-2020, 08:30 AM
Last Post: daniel
  My Daily QA - 2020-09-08 AmazingNutria 7 13,676 09-09-2020, 11:18 PM
Last Post: Cree
  My Daily QA - 2020-09-03 AmazingNutria 2 5,697 09-03-2020, 07:02 PM
Last Post: bcnaz
  My Daily QA - 2020-08-28 AmazingNutria 3 7,042 09-01-2020, 09:41 AM
Last Post: daniel
  My Daily QA - 2020-08-27 AmazingNutria 3 7,491 08-27-2020, 06:53 PM
Last Post: bcnaz
