How to safely add the Kali repository to Mobian
Exercise caution when employing this change; adding the Kali repository to Debian is not endorsed by Offensive Security, the Debian Project, or the Mobian project
echo 'deb http://http.kali.org/kali kali-rolling main non-free contrib' | sudo tee /etc/apt/sources.list.d/kali.list
wget -O - https://archive.kali.org/archive-key.asc | sudo apt-key add
echo -e '# Never prefer packages from the Kali repository\nPackage: *\nPin: release o=Kali\nPin-Priority: 1' | sudo tee /etc/apt/preferences.d/99kali
Kali packages are now accessible, and do not conflict with packages provided by Debian (or Mobian)
If a Kali package is preferable to its Debian equivalent, the package should be pinned
Inspired by this post about hijacking Mobian to run Bedrock Linux, here's how to add a Kali Linux stratum to Bedrock Linux.
While I hope apt pinning does not create a FrankenDebian, this method ensures distinction between Debian and Kali Linux.
wget https://github.com/bedrocklinux/bedrocklinux-userland/releases/download/0.7.17/bedrock-linux-0.7.17-aarch64.sh
sudo sh ./bedrock-linux-0.7.17-aarch64.sh --hijack
sudo reboot
A new Debian stratum has been bootstrapped and named Kali; the repositories will be changed to transform this stratum to Kali Linux.
sudo brl fetch -n kali debian
sudo strat kali apt install --no-install-recommends wget gnupg
strat kali wget -O - https://archive.kali.org/archive-key.asc | sudo strat kali apt-key add
printf '%s' 'deb http://http.kali.org/kali kali-rolling main non-free contrib' | sudo strat kali tee /etc/apt/sources.list
sudo strat kali apt update && sudo strat kali apt full-upgrade && sudo strat kali apt autoremove
Now Kali packages can be installed. To prefer (pin) stratum binaries, see /bedrock/etc/bedrock.conf.
wget: missing URL
Warning apt-key is deprecated. Manage keyring files in trusted.gpg.d instead.
Running the Mobian project
(02-17-2021, 05:41 AM)Brother Wrote: wget: missing URL
Check Kali upstream. I'm not using the PinePhone regularly anymore, and this post was just for fun. Cheers!
An addendum, apt-key should not be used as seen in the original post:
Quote:The key MUST be downloaded over a secure mechanism like HTTPS to a location only writable by root, which SHOULD be /usr/share/keyrings.
The key MUST NOT be placed in /etc/apt/trusted.gpg.d or loaded by apt-key add.
IME: your usually better off building these packages from the upstream source. I went through an entire "cyber security class" in college doing that on Alpine.
(08-10-2021, 06:08 AM)swiley Wrote: IME: your usually better off building these packages from the upstream source. I went through an entire "cyber security class" in college doing that on Alpine.
With cross-compilation, maybe... I don't like the idea of compiling on bare metal in this case Big Grin
To re-iterate, this post is outdated and was just for fun. I don't recommend using it as anything other than a novelty.
(08-15-2021, 02:52 AM)jed Wrote: I don't like the idea of compiling on bare metal in this case Big Grin
Why not? Half the reason I bought the phone was so I could compile stuff on it without hassle. I haven't had issues doing this.
  Mobian MMS/SMS text problem bcnaz 16 37,434 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,469 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 64,950 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 71,575 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,214 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 336,121 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,902 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,966 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,668 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 4,398 04-29-2025, 02:10 PM
Last Post: mdk
