USB Dock Flashes When Connected
So I chose this dock because the Wiki suggested it would work well:
https://www.amazon.com/gp/product/B07XKR...UTF8&psc=1
When I plugged it in unpowered, it seemed to work fine.  I got a USB-C to USB-C cable today and plugged it in, and it rapidly turned on and off.  I kept getting messages like:
[87032.432708] usb 7-1.1.4: new high-speed USB device number 69 using xhci-hcd [87032.684652] usb 7-1.1.4: New USB device found, idVendor=2109, idProduct=0101, bcdDevice= 2.03 [87032.684666] usb 7-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [87032.684673] usb 7-1.1.4: Product: USB 2.0 BILLBOARD            [87032.684680] usb 7-1.1.4: Manufacturer: VIA Technologies Inc.        [87032.684686] usb 7-1.1.4: SerialNumber: 0000000000000001 [87033.893737] usb 7-1: USB disconnect, device number 66 [87033.893749] usb 7-1.1: USB disconnect, device number 67 [87033.893755] usb 7-1.1.2: USB disconnect, device number 68 [87033.919565] usb 8-1: USB disconnect, device number 72 [87033.919583] usb 8-1.1: USB disconnect, device number 73 [87034.037223] usb 7-1.1.4: USB disconnect, device number 69 [87034.101502] usb 8-1.2: USB disconnect, device number 74 [87034.119502] cdn-dp fec00000.dp: [drm:cdn_dp_check_sink_connection [rockchipdrm]] *ERROR* Get sink capability timed out        [87034.119603] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] *ERROR* Enable dp failed -19        [87034.865090] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn [87034.872486] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn [87035.645057] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn [87035.884195] usb 8-1: new SuperSpeed Gen 1 USB device number 75 using xhci-hcd [87035.966055] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Connected, not enabled. Enabling cdn
It just keeps turning the power (and connection) on and off.  I'm on the default Manjaro and the only things plugged into the hub are the power and a USB mouse.  The power appears to work fine alone plugged directly  into the USB-C port, and the hub seems to work fine on my phone.
I'm stuck, any ideas?
Eh, looks like it's a bad dock. It didn't work under Debian either, so I switched out the power brick I was using. It worked fine for about 20 minutes, but had a high-pitched whine the entire time and got really hot. After heating up for a while, it just stopped working. I'm gonna call it a loss and maybe spend a bit more on a dock that won't do such things.
  pinebook pro dock display out mamboman777 0 2,931 07-29-2021, 10:41 AM
Last Post: mamboman777
  USB C dock with internal display mirrored to projector and one extended display jbrock 4 7,247 07-19-2021, 04:00 PM
Last Post: jbrock
  [SOLVED] Red light flashes next to barrel-port Carl 31 78,006 01-18-2021, 09:34 AM
Last Post: dsimic
  Pinebook Pro doesn't boot most of the time unless connected via USB-serial! nib0 16 25,807 09-29-2020, 10:24 PM
  USB-C Dock with HDMI no output coolmule 2 6,335 06-04-2020, 09:13 PM
Last Post: axel
