Power management under light load
I hope it is the right place to place the topic. Smile
I guess it worth to mention I read CRUST thread which is closely related to the topic. But it puts the device to sleep mode.
What I'm interested in is optimizing power drain for the device running under light to moderate load. For instance chatting or listening music.
My findings are:
  • brightness scales from 0 to 8 with range 0 - 300 mA;
  • cpu freq scales from 480 to 1152 KHz with range 300 - 600 mA;
  • good findings end here Sad
  • software disable modem/Wifi gives nothing (hw kill switch gives ~120 mA for both);
  • cpu cores online/offline gives nothing or even negative under load.
Conclusion: we can still save a lot Smile
If CRUST can help to save from modem/Wifi turn off, does anybody know anything about cpu governor work? I mean to really save energy with core offline.
I'd be interested here too. I don't have crust enabled, but I slapped a Python daemon together that on power button, shuts off the display, disables the touchscreen, shuts off all but 1 core, and scales the remaining one to 600Mhz. It doesn't save as much power as I'd hope. Phone still depletes way too fast.
I've also been working on messing around with the governor I have seen some impressive battery gains on android phones and thought I would see similar results. Unfortunately I didn't see any majorly noticeable improvements maybe an extra 1 hr. Results initially looked promising from battery graphs I was seeing but I quickly found out how awful the battery reporting is on this phone. One very interesting thing to me after tuning it was the phone no longer got unbearably hot. Which you would think since heat means energy loss I would have seen a great improvement in battery life but unfortunately I did not. I think considering the state of power management and being almost able to get through an entire day in it's current state this phone will eventually have an impressive battery life. However right now it needs work. Like @Subsentient said even throwing it into a state that would normally greatly improve battery life does little to nothing on this phone.
  Pilotlight, a way to save power during long audio playback biketool 3 6,056 01-10-2025, 03:42 AM
Lightbulb Article: Experiments for super low PinePhone power consumption with Genode Surehand53 1 4,692 12-27-2022, 02:21 PM
Last Post: Samurai_Crow
  Most Power Efficient OS Image jwinarske 0 2,249 07-05-2022, 07:05 PM
Last Post: jwinarske
  Keyboard Case Power Management Daemon estokes 2 5,251 04-16-2022, 04:15 PM
Last Post: estokes
  Diagnosing power usage with ZZZtop biketool 1 3,882 10-21-2021, 01:23 PM
  Reviewing our Forebearer's Work re:Power Consumption biketool 0 2,550 10-20-2021, 09:51 AM
  PSA: WiFi driver is broken - Unload kernel module to save lots of power Trbl 3 7,552 06-23-2021, 02:28 AM
Last Post: Merc
  Power Consumption Monitoring Software? Lousy Fisherman 0 3,000 11-22-2020, 03:20 PM
Last Post: Lousy Fisherman
  How to Monitor Power Management Changes? Lousy Fisherman 1 4,170 11-08-2020, 12:43 PM
  Clock and Power Rate running on Pinephone/Mobian Cynics 0 3,241 07-22-2020, 04:13 PM
Last Post: Cynics
