Diagnosing power usage with ZZZtop
If you remember the communities and dev teams behind OpenMoko or Neo900 you might know that Joerg_rw was an important EE behind these efforts he was also a very active community member and was responsible for many of the hardware function add-on hacks N900 users enjoyed.
I was IMing him today and he suggested we employ the very powerful tool zzztop to track down power issues in software and hardware which waste our battery charge.
zzztop is a fork of powertop(in the mobian repos but is optimized for x86/desktop) and is a ground up improved replacement for the custom closed source Nokia powertop-like tool developed in-house and not released.
zzztop likely needs some tweaks to get it to compile with modern libs but the source is linked in the Maemo wiki article below.
https://wiki.maemo.org/Zzztop
since I dont have zzztop compiled below is an example of powertop read over SSH from a 3/32 pinephone on battery running mobian
The battery reports a discharge rate of 2.62 W
The energy consumed was 55.6 J
Summary: nan wakeups/second,  nan GPU ops/seconds, nan VFS ops/sec and -0.0% CPU use
Power est.              Usage       Events/s    Category       Description
    0 mW      0.0%                      Device         runtime-1f015c0.codec-analog
    0 mW    100.0%                      Device         runtime-1c28000.serial
    0 mW    100.0%                      Device         runtime-1c15000.crypto
    0 mW    100.0%                      Device         runtime-1c22e00.codec
    0 mW    100.0%                      Device         runtime-musb-hdrc.4.auto
    0 mW    100.0%                      Device         runtime-1c10000.mmc
    0 mW    100.0%                      Device         runtime-1c28c00.serial
    0 mW    100.0%                      Device         I2C Device (2-0068): mpu6050
    0 mW      6.3 pkts/s                Device         Network interface: wlan0 (rtl8723cs)
    0 mW    100.0%                      Device         runtime-1f03400.rsb
    0 mW    100.0%                      Device         runtime-1c28400.serial
    0 mW    100.0%                      Device         Radio device: hci_uart_h5
    0 mW      6.0%                      Device         runtime-1c0f000.mmc
    0 mW      0.9%                      Device         runtime-1c11000.mmc
    0 mW      0.0%                      Device         runtime-reg-dummy
    0 mW      0.0%                      Device         runtime-1c2ac00.i2c
    0 mW      0.0%                      Device         USB device: Generic Platform OHCI controller
    0 mW     18.8%                      Device         USB device: EG25-G (Quectel)
    0 mW      0.0%                      Device         USB device: EHCI Host Controller
    0 mW     19.3%                      Device         USB device: EHCI Host Controller
    0 mW      0.0 pkts/s                Device         nic:vethZY3Ov2
    0 mW      0.0 pkts/s                Device         nic:lxcbr0
    0 mW      0.0 pkts/s                Device         nic:usb0
    0 mW      0.0 pkts/s                Device         nic:anbox0
    0 mW      0.0 pkts/s                Device         Network interface: wwan0 (qmi_wwan)
    0 mW      0.0%                      Device         runtime-1c19400.phy
    0 mW      0.0%                      Device         runtime-alarmtimer.0.auto
    0 mW      0.0%                      Device         runtime-1c0e000.video-codec
    0 mW      0.0%                      Device         runtime-hdmi-sound
    0 mW      0.0%                      Device         runtime-vbat-wifi
    0 mW      0.0%                      Device         runtime-1c20c00.timer
    0 mW      0.0%                      Device         runtime-1c0c000.lcd-controller
    0 mW      0.0%                      Device         runtime-1f02c00.pinctrl
    0 mW      0.0%                      Device         runtime-1c20000.clock
    0 mW      0.0%                      Device         runtime-1f03800.pwm
    0 mW      0.0%                      Device         runtime-1ef0000.hdmi-phy
    0 mW      0.0%                      Device         runtime-vcc5v0
    0 mW      0.0%                      Device         runtime-1c22800.i2s
    0 mW      0.0%                      Device         runtime-1c17000.mailbox
    0 mW      0.0%                      Device         runtime-ec25-codec
    0 mW      0.0%                      Device         runtime-usb_phy_generic.3.auto
    0 mW      0.0%                      Device         runtime-1c2b400.i2c
this is the zzztop perl script no compiling needed
I wanted to put it here it is GPLv2 by Phil Carmody (fatphil)
discussion here http://talk.maemo.org/showthread.php?t=92025
#!/usr/bin/perl -w
# Zzztop.pl
# Copyright 2013, Phil Carmody
# Inspired by "PowerTOP", but renamed as it's more concerned with
# sleeping than it is with the actual power consumed. Detects tasks
# that prevent the system from sleeping, in particular those that
# poll files or incorrectly poll() them, and ones that play ping-pong
# with each other.
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, version 3.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details. This can be found
# at <http://www.gnu.org/licenses/>.
use strict qw(refs vars subs);
use warnings;
my $verbose=1;
my $all=0; # show all frequencies (etc.?) even if data is 0
my $incompat=0; # more accuracy then maemo/meego's powertop means different results
# Need to select which timer to use. Time::HiRes may not be available
my ($xtime,$calibrate);
eval { require Time::HiRes; };
if(!$@) { $xtime = \&Time::HiRes::time; }
else {
    print STDERR "WARNING: Only low accuracy timing available.\n";
    sub xtime {
    open(S, "</proc/stat");
    <S>; $_=<S>;
    close(S);
    my @a=split(/\s+/);
    return ($a[1]+$a[2]+$a[3]+$a[4]+$a[5]+$a[6]+$a[7])/100;
    $xtime=\&xtime;
    $calibrate=1;
# Not every check is appropriate, depending on platform
my ($do_cpuidle, $do_cpufreq, $do_interrupts, $do_timerstats, $do_ctxtsw)=(1,1,1,1,1);
sub usage()
    print<<HELP
ZzzTop: show wakeup reasons, and other PM-related CPU info
Usage:
zzztop [-h] [-s=<nnn>] [-t=<nnn>] [-a]
  -h       this help text
  -s=<nnn> sleep for <nnn> seconds before collecting data
  -t=<nnn> collect data for <nnn> seconds
  -a       for some data gathered (cpufreq), show even 0 records
HELP
my ($sleep,$time)=(10,30);
while($_=shift(@ARGV)) {
    if(m/-s=(\d+)/) { $sleep=int($1); }
    elsif(m/-t=(\d+)/) { $time=int($1); }
    elsif(m/-a/) { $all=1; }
    elsif(m/-h/) { usage(); exit; }
    else { unshift(@ARGV, $_); last; }
my $mtime;
# gmtime(); # flush any one-time-only date prep now before the critical loop
my $cpudir='/sys/devices/system/cpu';
sub headstrip($)
    open(F, "<", $_[0]) or die("failed to read $_[0]");
    $_=<F>;
    close(F);
    chomp if($_);
    $_;
# BEGIN cpu
sub get_cpu_range()
    my $c=-1;
    my @cpus=glob("$cpudir/cpu[0-9]");
    foreach my $cpuname (@cpus) {
    my ($cpu)=($cpuname=~m/(\d+)$/);
    if($cpu>$c) { $c=$cpu; }
    print("Detected ".($c+1)." cpus\n")
    if($verbose);
    $c;
my $maxcpu=0;
$maxcpu = get_cpu_range();
if($maxcpu<0) {
    $do_cpuidle=0;
    print STDERR "All cpu-specific data gathering disabled - no $cpudir/cpu*\n";
# END cpu
# BEGIN cpuidle
sub get_cpuidle_ranges($)
    my $ret=$_[0];
    my $s=-1;
    foreach my $cpu (0..$maxcpu) {
    my @states=glob("$cpudir/cpu$cpu/cpuidle/state[0-9]*");
    my $t=-1;
    foreach my $state (@states) {
        my ($statenum)=($state =~ m/(\d+)$/);
        if($statenum>$t) { $t=$statenum; }
    if($t>=0) { $ret->[$cpu]=$t; }
    if($t>$s) { $s=$t; }
    print("Detected ".($s+1)." cpuidle states (@$ret)\n")
    if($verbose);
    $s;
my @maxstate;
my $maxstate = get_cpuidle_ranges(\@maxstate);
if($#maxstate<0) {
    $do_cpuidle=0;
    print STDERR "cpuidle disabled - no $cpudir/cpu*/cpuidle trees\n";
    print STDERR "                   enable CPU_IDLE in kernel config\n"
    if($verbose);
sub get_cpuidle_data() {
    my @ret=();
    $ret[$cpu]=[];
    foreach my $state (0..$maxstate[$cpu]) {
        my $time=headstrip("$cpudir/cpu$cpu/cpuidle/state$state/time");
        my $usage=headstrip("$cpudir/cpu$cpu/cpuidle/state$state/usage");
        $ret[$cpu]->[$state]=[$time,$usage];
    @ret;
sub diff_cpuidle($$)
    my ($pre, $post)=@_;
    print("C-state Information\n");
    print("===================\n");
    my @totalidle=();
    my $usagemax=0;
        my $dt = $post->[$cpu][$state][0] - $pre->[$cpu][$state][0];
        my $du = $post->[$cpu][$state][1] - $pre->[$cpu][$state][1];
        $totalidle[$cpu] += $dt;
        my $residence = $du ? int($dt/$du) : 0;
        if($residence > $usagemax) { $usagemax=$residence; }
    my ($usagescale, $usageletter)=(1,'u');
    if($usagemax>99999) { $usagescale=1000; $usageletter='m'; }
    my ($h1,$h2,$h3);
    $h1="    |";
    $h2=" C# |";
    $h3="----+";
    $h1.="      CPU#$cpu      |";
    $h2.="  time  | avg/${usageletter}s |";
    $h3.="--------+--------+";
    print("$h1\n$h2\n$h3\n");
    printf(" C%u |", 0); # active is the fake state C0
    printf(" %5.1f%% |        |", 100-$totalidle[$cpu]/($mtime*10000));
    print("\n");
    foreach my $state (0..$maxstate) {
    printf(" C%u |", $state+1);
        if($state<=$maxstate[$cpu]) {
        # times in us, so divide by 1000000, but want % so use 10000.
        # usage is number of transition
        printf(" %5.1f%% |  % 5s |",
               $dt/($mtime*10000),
               $du ? int($dt/$du/$usagescale) : "");
        } else {
        printf("        |        |");
    print("\n");
    #With the fake C0 record for active, there's no need for the idle sum too
    #print("Idle\t|");
    #foreach my $cpu (0..$maxcpu) {
    #    printf(" %4.1f%%\t|\t|", $totalidle[$cpu]/($mtime*10000));
    #print("\n");
    print("\n");
# END cpuidle
# BEGIN cpufreq
sub get_cpufreq_ranges()
    return -r "$cpudir/cpu0/cpufreq/stats/time_in_state" ? 0 : -1;
if(get_cpufreq_ranges()<0) {
    $do_cpufreq = 0;
    print STDERR "cpufreq disabled - no $cpudir/cpu*/cpufreq/stats/time_in_state\n";
    print STDERR "                   enable CPU_FREQ_STAT in kernel config\n"
    if($verbose);
sub get_cpufreq_data() {
    my @ret=();
    $ret[$cpu]={};
    open(F, "<$cpudir/cpu$cpu/cpufreq/stats/time_in_state") or die("cpufreq: 'read $cpudir/cpu$cpu/cpufreq/stats/time_in_state' $@");
    while(<F>) {
        if(m/(\d+)\s+(\d+)/) { $ret[$cpu]->{$1} = $2; }
        else { die("WTF is this doing in cpufreq: $_"); }
    close(F);
    # print("cpu$cpu -> ", join(" ",keys(%{$ret[$cpu]})), "\n");
    @ret;
sub diff_cpufreq($$)
    my ($pre, $post)=(@_);
    my %okfreq=();
    print("CPUfreq statistics\n");
    print("==================\n");
    my @totalticks=();
    my @freqs = sort { $a<=>$b } keys(%{$pre->[0]});
    $totalticks[$cpu]=0;
    foreach my $freq (@freqs) {
        my $dt = $post->[$cpu]->{$freq} - $pre->[$cpu]->{$freq};
        $totalticks[$cpu] += $dt;
        if($dt) { $okfreq{$freq}++; }
    my $h1="Frequency |";
    my $h2="----------+";
    $h1.="  CPU#$cpu |";
    $h2.="--------+";
    print("$h1\n$h2\n");
    if(!$all and !$okfreq{$freq}) { next; }
    printf(" %4u MHz |", int($freq/1000));
        printf(" %5.1f%% |", $dt*100/$totalticks[$cpu]);
    print("\n");
    print("\n");
# END cpufreq
# BEGIN interrupts
sub get_interrupt_names()
    open(I, "</proc/interrupts") or return undef;
    my @ret=();
    while(<I>) {
    if(m/^\s+CPU\d/) { next; }
    elsif(m/\s*(\w+):\s+\d/) { push(@ret, $1); }
    else { print("interrupts: what's: $_"); }
    close(I);
    @ret;
my @interrupt_names=get_interrupt_names();
if(scalar(@interrupt_names)<=0) {
    $do_interrupts = 0;
    print STDERR "interrupts disabled - no /proc/interrupts\n";
sub get_interrupt_data() {
    my @ret=();
    open(I, "</proc/interrupts");
    while(<I>) {
    if(m/^\s+CPU\d/) {
        foreach my $cpu (0..$maxcpu+1) { $ret[$cpu]={}; }
        next;
    } elsif(s/\s*([\w]+):\s+//) {
        my $int=$1;
        s/(\d+)\s+//;
        if($maxcpu>0 && !length($_)) { last; }
        $ret[$cpu]->{$int}=$1;
        chomp;
        $ret[$maxcpu+1]->{$int} = $_;
    close(I);
    @ret;
sub diff_interrupts($$)
    my %okirq=();
    my @output=();
    my @activity=();
    my $total=0;
    foreach my $int (@interrupt_names) {
    if($maxcpu>0 and !exists($pre->[1]->{$int})) { next; } # ERR or MIS, cpu-less
    my $line=sprintf("%4s |", $int);
    my $doit=0;
        my $dt = $post->[$cpu]->{$int} - $pre->[$cpu]->{$int};
        $line.=sprintf(" % 5u |", $dt);
        $doit+=$dt;
    if($doit) {
        push(@output, "$line $pre->[$maxcpu+1]->{$int}\n");
        push(@activity, $doit);
        $total+=$doit;
    print("Interrupt statistics\n");
    print("====================\n");
    my $h1=" INT |";
    my $h2="-----+";
    $h1.=" CPU#$cpu |";
    $h2.="-------+";
    my @indices = sort { $activity[$b]<=>$activity[$a]; } (0..$#activity);
    foreach(@indices) { print($output[$_]); }
    printf("Summary: %3.1f interrupts/s total\n", $total/$mtime);
    print("\n");
# END interrupts
# BEGIN timerstats
sub get_timerstats()
    open(T, ">/proc/timer_stats") or return -1;
    print T "0\n";
    close(T);
    0;
if(get_timerstats()<0) {
    $do_timerstats = 0;
    print STDERR "timerstats disabled - no writeable /proc/timer_stats\n";
    if($> != 0) { print STDERR "                      you need to be root!\n"; }
    elsif($verbose) {
    print STDERR "                      enable TIMER_STATS in kernel config\n";
sub get_timerstats_data($) # 1 then 0
    my $stop=$_[0];
    open(T, ">/proc/timer_stats") or die("timerstats: open() failed: $@");
    print T (($stop?1:0),"\n");
    close(T);
sub diff_timerstats()
    my $ok=1;
    my @output=();
    my @activity=();
    open(T, "</proc/timer_stats") or die("timerstats: open() failed: $@");
    while(<T>) {
    if(m/Timer Stats Version/) { next; }
    if(m/Sample period: ([\d.]+)\s*s/) { if($1 eq "0.000") { $ok=0; last; } }
    if(m/(\d+) total events/) { if($1 eq "0") { $ok=0; last; } }
    if(m/\s+(\d+)(D?),\s+(\d+)\s(\S+)\s+(.*)$/) {
        push(@output, sprintf(" % 5s | % 8s%1s| % 15s | %s\n",
                  $3, $1, $2, $4, $5));
        push(@activity, $1+($3*10e-9)); # decimals keep tasks together ;-)
    close(T);
    if(!$ok) {
    print("Timerstats was unable to gather any data from /proc/timer_stats\n\n");
    return;
    print("Timer statistics\n");
    print("================\n");
    print("   PID | Activity |     task's comm | function\n");
    print("-------+----------+-----------------+---------\n");
    print("\n");
# END timerstats
my %taskinfo=();
my $taskinfodone=0;
sub get_task_info($)
    my $cmd=headstrip("/proc/$_[0]/cmdline");
    if($cmd) {
    $cmd=~tr/\0/ /;
    $cmd;
sub get_tasks_info($) {
    if(!$_[0] and $taskinfodone) { return; }
    for my $p (glob("/proc/[0-9]*")) {
    my ($pid)=($p=~m@/proc/(\d+)@);
    $taskinfo{$pid}=get_task_info($pid);
# BEGIN context switch stats
sub get_ctxtsw_init()
    get_tasks_info(0);
    0;
if(get_ctxtsw_init() < 0) {
    $do_ctxtsw = 0;
    print STDERR "context_switches disabled - this is unexpected\n";
sub get_ctxtsw_data()
    my %ret=();
    open(T, "$p/status") or next;
    my @v=();
    my $luserspace=0;
    my ($name)=(<T>=~/Name:\s+(\S+)/);
    while(<T>) {
        if(m/^(Vm|State:\s+Z)/) { $luserspace=1; }
        elsif(m/(\S*)voluntary_ctxt_switches:\s+(\d+)/) {
        $v[length($1)?1:0] = $2;
    if(!defined($taskinfo{$pid})) {
        $taskinfo{$pid} = $luserspace ? get_task_info($pid) : "<$name>";
    close(T);
    $ret{$pid}=\@v;
    %ret;
sub diff_ctxtsw($$)
    print("Context switches per task\n",
      "=========================\n");
    print("  PID  | vol'try | non-vol | Cmdline\n",
      "-------+---------+---------+--------\n");
    my @postpids=sort { $b<=>$a; } (keys(%$post));
    foreach my $p (@postpids) {
    my $prevals = $pre->{$p} || [0,0];
    my $dv=$post->{$p}->[0] - $prevals->[0];
    my $dn=$post->{$p}->[1] - $prevals->[1];
    printf(" % 5u | % 7u | % 7u | %s\n", $p, $dv, $dn, $taskinfo{$p})
        if($dv || $dn);
    print("\n");
# END context switch stats
if(!$do_cpuidle && !$do_cpufreq && !$do_interrupts && !$do_timerstats && !$do_ctxtsw) {
    print "No statistics can be gathered, aborting\n";
    exit;
# Timing preparations
print("Sleeping for $sleep seconds before collecting data for $time seconds\n");
my ($timepre1, $timepre2, $timepost1, $timepost2);
my $timecali=&$xtime if($calibrate);
sleep($sleep);
$timepre1=&$xtime;
if($sleep and $calibrate) {
    my $measured=$timepre1-$timecali;
    my $ratio=$measured/$sleep;
    if($ratio>1.01 or $ratio<0.99) { print("WARNING: No accurate timer found, relying on sleep itself.\n"); }
    else { $calibrate=0; } # we trust this measure
# Now actually gather the data
my %ctxtsw_pre=get_ctxtsw_data() if($do_ctxtsw);
my @cpuidle_pre=get_cpuidle_data() if($do_cpuidle);
my @cpufreq_pre=get_cpufreq_data() if($do_cpufreq);
my @interrupts_pre=get_interrupt_data() if($do_interrupts);
get_timerstats_data(1) if($do_timerstats);
$timepre2=&$xtime;
sleep($time);
$timepost1=&$xtime;
my %ctxtsw_post=get_ctxtsw_data() if($do_ctxtsw);
my @cpuidle_post=get_cpuidle_data() if($do_cpuidle);
my @cpufreq_post=get_cpufreq_data() if($do_cpufreq);
my @interrupts_post=get_interrupt_data() if($do_interrupts);
get_timerstats_data(0) if($do_timerstats);
$timepost2=&$xtime;
# @$mtime is the measurement time, which will probably be
#         longer than the time we requested.
if($calibrate) {
    $mtime = $time;
    printf("Presumably slept for %1.3fs\n", $mtime);
} else {
    $mtime =($timepost1-$timepre2); # how long the sleep took
    $mtime += (($timepre2-$timepre1)+($timepost2-$timepost1))/2
    if($incompat); # plus the overhead of reading the values
    printf("Actually slept for %1.3fs\n", $mtime);
diff_cpuidle(\@cpuidle_pre, \@cpuidle_post) if($do_cpuidle);
diff_cpufreq(\@cpufreq_pre, \@cpufreq_post) if($do_cpufreq);
diff_interrupts(\@interrupts_pre, \@interrupts_post) if($do_interrupts);
diff_timerstats() if($do_timerstats);
diff_ctxtsw(\%ctxtsw_pre, \%ctxtsw_post) if($do_ctxtsw);
Thanks on Joel advise :-)
  Pilotlight, a way to save power during long audio playback biketool 3 5,890 01-10-2025, 03:42 AM
Lightbulb Article: Experiments for super low PinePhone power consumption with Genode Surehand53 1 4,628 12-27-2022, 02:21 PM
Last Post: Samurai_Crow
  Most Power Efficient OS Image jwinarske 0 2,189 07-05-2022, 07:05 PM
Last Post: jwinarske
  Keyboard Case Power Management Daemon estokes 2 5,149 04-16-2022, 04:15 PM
Last Post: estokes
  Reviewing our Forebearer's Work re:Power Consumption biketool 0 2,500 10-20-2021, 09:51 AM
  PSA: WiFi driver is broken - Unload kernel module to save lots of power Trbl 3 7,452 06-23-2021, 02:28 AM
Last Post: Merc
  Power Consumption Monitoring Software? Lousy Fisherman 0 2,958 11-22-2020, 03:20 PM
Last Post: Lousy Fisherman
  How to Monitor Power Management Changes? Lousy Fisherman 1 4,113 11-08-2020, 12:43 PM
  Clock and Power Rate running on Pinephone/Mobian Cynics 0 3,198 07-22-2020, 04:13 PM
Last Post: Cynics
  pplockd: Simple power management/CRUST daemon for X11 GUIs on PinePhone Subsentient 1 5,614 07-04-2020, 06:39 AM
Last Post: Subsentient
