Led label on the board
I found out that on the Pine64 1GB has a LED label.
What could I do with this connection?
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 3,549 10-06-2022, 08:46 PM
Last Post: ihab
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 27,220 05-15-2019, 02:55 PM
Last Post: Thatoo
  My first Single Board! jjh221 4 11,175 04-09-2018, 06:52 PM
Last Post: jjh221
  sopine cluster board install Smurfbot 1 7,010 03-31-2018, 04:09 AM
Last Post: pfeerick
  What is the format that one should use for imaging SD cards on APINE64+2GB Board? Doryan 1 6,018 03-05-2018, 08:11 PM
  Which board to use? Dayve 0 3,869 02-18-2018, 06:31 AM
Last Post: Dayve
  Kodi on Rock64 board cenguix 2 12,018 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
  What are these pins on PIN board? dims 1 5,455 01-15-2018, 11:21 AM
Last Post: Luke
  What is on the Micro SC card that came with the board? clawinus 1 6,294 11-03-2016, 02:33 PM
Last Post: MarkHaysHarris777
  Power Switch for Pine64 512MB Board MonarchOfLight 0 4,216 10-24-2016, 04:33 PM
Last Post: MonarchOfLight
