08-10-2021, 04:12 PM
When I try to have a call on speaker, the other person hear loud noises (noise, not echo or reverb).
Is it the same for you ?
im using an os based on arch.
If you want to replicate the bug, make a call and in alsamixer mute earphone, unmute speaker, enable mic1 boost, and see if the other side hear noise.
Thanks.
(08-10-2021, 04:12 PM)jack1 Wrote: When I try to have a call on speaker, the other person hear loud noises (noise, not echo or reverb).
Thanks.
Most likely, it audio coupling of the speaker to the microphone, with a lesser chance of being electrical coupling. Note that with the speaker muted, there could still be some noise (see https://forum.pine64.org/showthread.php?tid=13922) but with the speaker unmuted, the speaker is most likely the primary cause.
(08-14-2021, 09:25 AM)vortex Wrote: Most likely, it audio coupling of the speaker to the microphone, with a lesser chance of being electrical coupling...
Thanks. You have read when i wrote "noise, not echo or reverb" right ? its like the noise of a radio that has no signial...
Important is if it happend only to me...
(08-14-2021, 04:08 PM)jack1 Wrote: (08-14-2021, 09:25 AM)vortex Wrote: Most likely, it audio coupling of the speaker to the microphone, with a lesser chance of being electrical coupling...
If you get it when the speaker is muted, it is definite what was in the thread I linked ( https://forum.pine64.org/showthread.php?tid=13922). If it is only there when the speaker is operating or is worse, then it is probably electrical coupling.
That all said, there is a way to investigate it. If during a call, you record your phone's microphone to a file, download it to your computer, and look at a powerspectrum of it; there might be some clues. I wrote a convenient tool for the other thread that can help with the power spectrum part, which is pinephone_call_noise_investigation, that when given the recording as a WAV file will plot the spectrogram and optionally write it to a CSV. My most recent powerspectrum looked like
If you get a frequency comb like this, then it is likely you have the same issue or a related one.
08-15-2021, 02:56 PM
(This post was last modified: 08-15-2021, 02:58 PM by jack1.)
thanks, ill try.
Anyway it happend when the speaker is on and the 'mic1 boost' is active (max vol or > 0) (talking about alsa)
@ vortex
I tryed your app ( u r a girl ? ![Heart Heart](https://forum.pine64.org/images/smilies/heart.png) )
I left the default nperseg. The file is 41 seconds, 8khz
Does it tell you something ?
(08-20-2021, 04:31 PM)jack1 Wrote: I left the default nperseg. The file is 41 seconds, 8khz
There is no frequency comb (equally spaced spikes). Looks like broadband noise.
(08-20-2021, 04:31 PM)jack1 Wrote: @vortex
I tryed your app ( u r a girl ? )
Seriously?
(08-21-2021, 04:43 AM)vortex Wrote: Seriously?
Believe me, you're not alone.
This message was created with 100% recycled electrons
Thanks.
I am on Mobian nightly, one phone on the most recent nightly, and my daily phone is on an updated copy of a July release.
When I have ether phone on speaker, they ' hear a noise on their end ' ... While It sounds really good at my end.
I turned down the microphone volume in settings, and they say it does ' improve ', but the noise does not go away.
When the speaker mode is off the sound is fine on both ends.
LINUX = CHOICES
**BCnAZ**
Donate to $upport
your favorite OS Team
08-22-2021, 05:49 PM
(This post was last modified: 08-22-2021, 05:54 PM by jack1.)
@ vortex
I made another graph recording directly the from mic, also the wave;
@ bcnaz Look like the same bug ! I wonder how many has this !
I forgot, I also have the vibrator broken. Could be related ? a usb-board hardware problem ?
