07-28-2021, 01:07 AM
Would you consider adding current .deb and .rpm builds to your git?
When I do a reinstall I usually grab the installed packages list first and then can re-add the software I had.
I often end up missing some of the apps I had to do a make install.
Again thanks for Compass!
