What's your experience with the updated touchpad firmware?
Feels nearly perfect
65.93%
60
Better, but still not issue-free
26.37%
24
No real improvements
3.30%
3
Firmware update failed
4.40%
4
91 vote(s)
Finally... The touchpad works great!
#21
(07-28-2021, 05:00 PM)kirfkin Wrote: Has anyone noted if this stops the random jumps (typically to the bottom left)? If so, it ends my last major frustration with the Pinebook Pro.
I was experiencing that prior to this update.  I haven't had that happen since the update.  I'll let you know if it pops up again, but for the moment, it appears to be gone.
I'm using the ANSI model. After the update, it appears that the "disable while typing" is not working. I have tried changing the setting in the gui on Manjaro. Anyone have ideas?
I got my PBP back in Nov 2019. It's a 128gb version. Just did the firmware update and it went like a breeze. I feel like I have a new laptop on my lap. Smile
About the revised keyboard firmware: you say it's fixing some of the common issues people are facing. I was facing a random key repeat issue, it seems it's gone now. Was it one of the common issues?
Great work! Thanks!
Good news. I'll hold off just a bit longer to see if it's reported; especially with respect to the disable while typing. I have big hands so that can be immensely useful.
This is exciting. Thank you. Unfortunately, Step 1 bricked my keyboard on Manjaro. Oh well.
[Edit: I connected an external keyboard, continued with the rest of the steps and now the internal keyboard is back. That was scary.]
(07-29-2021, 12:09 PM)dennisfaucher Wrote: This is exciting. Thank you. Unfortunately, Step 1 bricked my keyboard on Manjaro. Oh well.
I learned that the hard way too!  They do mention it in the git page, but it's still scary.  Glad to see you on the other side!
It should go without saying that a keyboard firmware update should be done with a second keyboard handy. Smile
:wq
Didn't work for me. I took a screenshot of the terminal output figuring it'd help but there's no way to attach images directly to the forum.
>>> Verify mismatch: type=f2, pass=e2, received=d2
EEE Touchpad verify data failed type:242 pass:226
EEE Touchpad erase failed
>>> USB device closed
The verify mismatch line gets spammed a hundred times before finally giving up and outputting the last three lines. My keyboard is ANSI, but my PBP is a first-run ISO model. I wouldn't think that there'd be ISO trackpads and ANSI trackpads that would cause the script to fail, but I honestly don't know. Right this second the trackpad doesn't work at all and the keyboard doesn't work but certain keys output letters not assigned to them, so it's probably not completely dead, hopefully, fingers crossed.
Is it fubar or is there still hope yet?
Updated my ANSI KB and touchpad on Fedora without issue.  Touchpad is much improved.
On Fedora I had to install libusb-devel and xxd
sudo dnf install libusb-devel xxd
Thanks again
Thanks so much for the update!
The initial delay was such a bummer, so this is a great relief and very much appreciated.
Update worked great, ANSI keyboard PBP. Just had to dig an old USB keyboard out of a box Smile
  Ubuntu 25.04 beta works, kinda RMJ250 3 3,638 04-14-2025, 09:01 PM
Last Post: RMJ250
  PBP green LED works but blank display. frerebo 1 2,476 02-22-2023, 03:11 AM
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 6,818 09-14-2022, 03:56 AM
Last Post: Carl
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 5,136 02-05-2021, 09:10 AM
Last Post: BlueJayLinux
  Sticker on touchpad fbkr 3 7,557 11-10-2020, 10:10 PM
Last Post: pFalken
  Touchpad self generates events jpalus 0 2,966 10-18-2020, 11:38 AM
Last Post: jpalus
  Do I need the touchpad update? Paulie420 3 8,107 09-22-2020, 06:40 PM
Last Post: Paulie420
  touchpad tanzim8145 2 6,833 06-06-2020, 02:56 AM
Last Post: lot378
Bug open wifi works and secure wifi does not j3bel 2 5,874 06-02-2020, 01:55 PM
Last Post: j3bel
  Right Click touchpad sensitivity tomfowler 4 8,956 05-31-2020, 12:32 PM
Last Post: gwalker
