Quectel EG25-G H/W interface - Operating Modes - eg25-manager
Quectel EG25-G hardware connection
Studying page 15 of Pinephone's mainboard schematic for the modem
https://files.pine64.org/doc/PinePhone/P...ematic.pdf
we can see that we have a chip with 144 contacts where half of them are actually connected. Physically half of them are SMD pins around the chip and the rest are balls under the chip.
Most of the connected pins are electrical grounding while the rest are voltage power, data lines, sychronisation lines and antennae.
Pins
14-17 -----> go to the SIM
35, 47, 49 -----> are the antennae
2 -----> BB-AP-READY |
4 -----> BB-DISABLE | -----> are controlling the power state of the modem and are driven by the eg25-manager
20 -----> BB-RESET |
21 -----> BB-PWRKEY |
7 -----> is output power
57-60 -----> are battery power
71 -----> is the battery power for the USB
115 -----> is the test button
8, 9, 19, 22, 36, 46, 48, 50-54, 56, 72, 85-112 -----> are ground
24-27 -----> are the PCM audio interface
62 -----> is the ringing indicator
64-68 -----> is the UART interface
69, 70 -----> are the USB (+),(-) differential lines
We further see that the PCM, UART and the AP_READY,DTR signals pass through TXB0104YZT chips which are DC voltage converters but without using the inverting technique.
The communication with the A64 SoC is achieved by connecting the
1) power control lines
2) UART
3) USB
4) PCM
to GPIO contacts of the A64 which can be easily accessed by the kernel for reading and writing operations.
The audio data for calls are transferred by connecting the PCM contacts of the modem to the GPIO contacts of the A64 and the processing is done by the sound module in the SoC which is interfaced by ALSA.
A64 GPIO pins
The datasheet for A64 is here
https://files.pine64.org/doc/datasheet/p...t_V1.1.pdf
As we can see in 4.2 (page 23), the GPIO pins are divided in categories with different capabilities denoted in the following way
PB0 - 9 -----> 10 pins
PC0 -16 -----> 17 pins
PD0 - 24 -----> 25 pins
PE0 -17 -----> 18 pins
PF0 - 6 -----> 7 pins
PG0 -13 -----> 14 pins
PH0 -11 -----> 12 pins
PL0 -12 -----> 13 pins
Total: 116 pins
Operating Modes
1) Normal Operation
a) Idle: Software is active. The module has registered on the network, and it is
ready to send and receive data.
b) Talk/Data: Network connection is ongoing. In this mode, the power consumption is
decided by network setting and data transfer rate.
2) Minimum Functionality
Mode AT+CFUN=0 can set the module to a minimum functionality mode without removing
the power supply. In this case, both RF function and (U)SIM card will be invalid.
3) Airplane Mode
AT+CFUN=4 or W_DISABLE# pin can set the module to enter airplane mode. In this
case, RF function will be invalid.
4) Sleep Mode
The current consumption of the module will be reduced to the minimal level. During
this mode, the module can still receive paging message, SMS, voice call and
TCP/UDP data from the network normally.
5) Power Down
Mode The power management unit shuts down the power supply. Software goes inactive.
The serial interface is not accessible. Operating voltage (connected to VBAT_RF and
VBAT_BB) remains applied.
You can easily switch between modes 1,2,3 by
`echo at+cfun=1,0 | sudo atinout - /dev/EG25.AT -`
`echo at+cfun=0,0 | sudo atinout - /dev/EG25.AT -`
`echo at+cfun=4,0 | sudo atinout - /dev/EG25.AT -`
mode 5 can be achieved with
`echo at+qpwd=1| sudo atinout - /dev/EG25.AT -`
eg25-manager
The source code of the manager can be found here
https://gitlab.com/mobian1/devices/eg25-manager
Studying the directory tree we can see 3 directories.
1) "data", contains configurations files in ".toml" format which are installed in `/usr/share/eg25-manager`
2) "src", contains the source code
3) "udev", contains standard udev rules for the modem
The "src" directory contains two types of files, the ".c" source code and the ".h" header files for the respective ".c" files.
We can see the following files
1) at.c/.h - renders the AT commands defined in the ".toml" configurations files
2) gpio.c/.h - for the communication with the GPIO interface of the A64
3) manager.c/.h - the eg25-manager
4) mm-iface.c/.h -  for the communication with distributions using the ModemManager service
5) ofono-iface.c/.h - for the communication with distributions using the ofono service
6) suspend.c/.h - provides the ability to suspend the modem to sleep
7) toml.c/.h - for processing the ".toml" cofiguration files
8) udev.c/.h - for processing the udev rules
How it works
The main sequence of the code starts in "manager.c" at
`int main(int argc, char *argv[])`
1) it initialises some data structures,
2) reads the configuration files,
3) initialises the gpio chips (1c20800.pinctrl & 1f02c00.pinctrl)
4) takes actions on the modem (power on/off, suspend, wake, sleep) by sending and reading signals to and from the modem pins
4 -----> BB-DISABLE
20 -----> BB-RESET
21 -----> BB-PWRKEY
As we can see in the "gpio.c" code those signals are send easily via the "gpiod" library by calling functions like
`gpiod_line_set_value(manager->gpio_out[GPIO_OUT_PWRKEY], 1);`
You can find more information on the "gpiod" library here
https://www.ics.com/blog/gpio-programmin...od-library
.pdf   Quectel_EG25-G_Hardware_Design_V1.4-edit.pdf (Size: 947.14 KB / Downloads: 1,001)
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 6,961 02-05-2025, 02:30 AM
  PinePhone Beta dead - no boot-related output on serial interface horalocal 1 3,975 02-15-2023, 11:21 AM
Last Post: fxc
  firmware udate Quectel EG25-G modem alwi 7 16,013 07-06-2022, 01:43 PM
Last Post: user641
  CVE-2021-31698 - Quectel Eg25-g AT Command Injection jtn0514 2 7,013 09-30-2021, 12:26 PM
Last Post: megous
  Quectel T-Mobile Certification and MMS manuals mouffa 2 6,155 08-08-2021, 04:28 AM
Last Post: mouffa
  Quectel EG25-G GNSS Configuration and location tracking mouffa 2 14,221 06-07-2021, 04:24 AM
Last Post: mouffa
  Quectel EG25-G Modem Configuration - ofono - Manjaro Plasma mouffa 5 12,175 06-02-2021, 11:38 AM
Last Post: mouffa
  Wifi/BT interface not detected aithal 17 29,549 05-30-2021, 11:10 AM
Last Post: Krasimir
  EG25-G support for emergency alerts (WEA/CMAS) newton688 5 12,392 07-01-2020, 11:35 AM
Last Post: wibble
  Heat build-up: EG25 or SOC? CloudHackIX 5 10,538 02-24-2020, 08:52 PM
Last Post: CloudHackIX
