Axolotl signal client package
as I never managed to run Axolotl using flathub / snap packages, I've built an Arch AUR package that works at least for me (phosh).
https://aur.archlinux.org/packages/axolotl-bin/
Installation:
pamac install axolotl-bin
It just repackages the mobian binairies for Arch (see https://github.com/nuehm-arno/axolotl-mobian-package ). Hope it helps.
This wouldn't happen to work on Mobian+phosh, would it?
OS: Mobian Bookworm, Phosh. Pinephone Braveheart from 2020-02-11
(06-20-2021, 05:12 PM)quixote Wrote: This wouldn't happen to work on Mobian+phosh, would it?
For Mobian I suppose you just have to download https://github.com/nuehm-arno/axolotl-mo..._arm64.deb
Then run
sudo apt install ./axolotl_1.0.0-1_arm64.deb
(06-21-2021, 04:04 AM)lolgzs Wrote: For Mobian I suppose you just have to download https://github.com/nuehm-arno/axolotl-mo..._arm64.deb
Then run
Yes, I got sandbagged at a certain point trying to get that running. (My mistakes.) I'll have to make a fresh start. I thought maybe trying something totally different would help ... Big Grin
(06-18-2021, 01:09 AM)lolgzs Wrote: Hi,
Installation:
The holy tux may bless you! Since more than one year I'm trying to use signal on the pinephone without success (still struggling on postmarket os). Now it's my daily driver with manjaro. I can also connect the signal desktop client to the axolotl client. Great! Thank you so much.
In plasma mobile app starts but cannot enter my phone number. No keyboard pops up
(07-01-2021, 08:42 AM)firefox-58 Wrote: In plasma mobile app starts but cannot enter my phone number. No keyboard pops up
May be there's some problems with plasma mobile detecting inputs in electron apps....
You may try this: in a terminal, launch axolotl in server mode:
axolotl -e server
Then run angelfish / firefox web browser and open url: http://127.0.0.1:9080
The process now hangs after selcting the correct captcha(s) with a white screen containing a reload icon
(06-18-2021, 01:09 AM)lolgzs Wrote: ...
Many thanks - just learning about AUR in arch and it builds/installs fine in arch. And by copying the textsecure directories from my Mobian instance have my historic setup/config/threads!
I tried the manual build for Mobian 3 or 4 different times and it has failed every time for me (even though it seems to work for a lot of other people), is this literally just running the AUR line or is there more to it than that? I am at work so I can't test of Manjaro Phosh.
  No keyboard in Signal Desktop Kimberley van Buyten 4 6,862 10-16-2022, 10:25 AM
Last Post: Eugo
  Plasma mobile email client Athansor 9 17,562 11-18-2021, 02:00 AM
Last Post: ryo
  Pandora music streaming client jtn0514 0 2,457 09-27-2021, 07:51 PM
Last Post: jtn0514
  xmpp&jabber client for Manjaro Plasma mobile acrux 15 23,913 09-13-2021, 10:02 PM
Last Post: TRS-80
  How do you install VPN so you can set up a config file, tor, signal and disk encrypt? temp0rary 5 8,869 05-30-2021, 08:14 PM
Last Post: temp0rary
  Ensure Up To Date - Manjaro Plasma Discover Package Manager Sources Linux2thabone 0 2,913 05-05-2021, 11:15 AM
Last Post: Linux2thabone
