Convergence: battery is constantly discharging/charging
Hi folks,
Today I share an interesting find with the PinePhone's battery profile when using it with the convergence dock.
I've installed Cronie and shell script which sends the battery voltage and level (percentage) to my RPi server every minute. (from /sys/class/power-supply/axp20x-battery/)
The server then is able to plot a graph of these measurements.
When fully charged (at 86%, due to the 4.2v safety limit being applied) and plugged in with convergence dock (USB-c charger, HDMI display, usb keyboard/mouse, media playing so it won't go to sleep), the graph reveals that the battery does not stay at the same level but constantly discharges and then recharges again.
With a laptop for example, this does not happen. It stays at 100% and the voltage is constant.
How does this affect the battery in terms of longevity and efficiency?
This is rather interesting, thank you for sharing!  Could you, please, provide the output of the following command as well, in the scenario you've decribed in your post, i.e. with the official dock connected to the phone, the same USB Type-C charger connected to the dock, etc.:
cat /sys/class/power_supply/axp20x-usb/uevent
Did you experience any flickering of the phone's screen backlight while running those tests?
Could you also, please, re-run the data acquisition and plotting of the charts with the same USB Type-C charger connected directly to the phone, i.e. without using the official dock?  Please, provide the second output of the command above as well.
I'm pretty sure this is intentional. I seem to remember reading that cyclical charging/discharging is a feature of the operating system to increase battery life.
The only reason I recall that is that I recall thinking how much I hated the phone I had that did this, when I read about the Pinephone doing it. There's nothing more irritating than charging your phone overnight and having it at 50% when you need it in the morning.
Please, have a look at this forum post, in which I've described in detail the background of why the PinePhone battery doesn't charge to 100% in the default configuration, how to change that if desired, and why changing that isn't the best idea at the moment.  As a note, the original question in this thread is about the phone battery constantly discharging a little and charging back, despite the charger being connected all the time.
The reason that the phone discharges slowly, even though a charger is connected is because the modem and the WiFi chip is connected directly to the battery. The two items can therefore never be powered directly from USB charger.
For same reason, if you have discharged your battery to 0% (<=3.0V), and you power up the phone from USB, you will most like see, that WiFi and Modem is not working on the phone. Battery has to be charged to over 3.5V, before they will work again.
This has btw nothing to do with the dock - the phone does the same with power connected directly to the USB port.
That's correct, Alho.  Thank you for pointing it out!  As a note, following the "4G-VBAT", "VBAT_BB" and "VCC-WIFI" labels in the PinePhone schematic clearly shows where the modem and the WiFi/BT module get their power from.
  Battery connector dead mdk 5 4,174 01-15-2026, 02:24 PM
Last Post: mikeb
  Battery Life- hardware abstraction layer-GPU VS optomizing app for GPU-openGL biketool 1 3,172 09-20-2024, 04:04 AM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 4,938 02-17-2024, 04:15 PM
Last Post: vortex
  PinePhone constantly vibrating and won't take charge ImmyChan 5 9,692 07-23-2023, 03:49 PM
Last Post: kb-zealot
  Battery life improvement freelectro 10 11,318 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 5,138 03-20-2023, 12:54 AM
Last Post: bcoyle
  No calls on Pine Phone Beta convergence edition polypode 1 3,540 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  Charging Indicator On - Not Charging SJSEng 0 2,125 08-30-2022, 07:33 AM
Last Post: SJSEng
  Power supply vs battery albafrati 11 12,505 06-22-2022, 06:04 PM
Last Post: albafrati
  Issues with HDMI-out from convergence dock folgaran 1 3,016 06-16-2022, 04:35 PM
Last Post: alaraajavamma
