Tip disconnected
Hi all !
I've received today a USB C cable, and could finally test my pinecil in good conditions. I've run a test with a barrel connector when I first received the iron, but the connector was too small to fit into the plug, so I had to keep it in place with one hand !
So, I've started to look at what settings are available in the menu, and once I had done a tour, wanted to try using it. I had a strange problem, which was a steady "420 °C" where the display usually flickrs quickly around the set temperature. I eventually discovered that the tip was at room temperature, and the detailled idle screen told me that the tip was disconnected. I've tested each one of the 5 tips I have, that are all new and unused, same problem.
Anybody having the same problem ? What kind of solution may be applied to this ?
i've found another thread discribing the exact same problem, here : https://forum.pine64.org/showthread.php?tid=12673 but there is no indication that the problem has been solved...
Thank you all !
Hello to all.
it's been a long time since this post. I've wrote to pine64 to expose the problem, and they kindly sent a new working one to me. However, I needed to try and resolve this problem.
It appears that the problem was caused by a succession of events :
The iron was first working, but suddenly displayed a crazy, steady temperature.
It was then auto-calibrated, which gives back a normal temperature on the screen, but says that there is no tip.
After thinking that maybe the tip is broken for whatever reason, I've tried every one I had (the one that came with plus the four tips in the kit), each one of them bringing the same "tip disconnected" message.
Here is the trick : when I've started to have this crazy temperature, it was because of a dead tip. And I've recalibrated the iron with this dead tip, so every other one I tried didn't appears, because the software sees whatever resistive value beyond the threshold of a working tip. By recalibrating the iron with each other tips, I finally had it back, with the normal behavior of dead tips having the display saying "disconnected", and working ones displaying the temperature.
Hope it will help ! And that maybe a check could be added to the hardware / software ?
(05-11-2021, 04:09 AM)troisis_type Wrote: Here is the trick : when I've started to have this crazy temperature, it was because of a dead tip. And I've recalibrated the iron with this dead tip, so every other one I tried didn't appears, because the software sees whatever resistive value beyond the threshold of a working tip. By recalibrating the iron with each other tips, I finally had it back, with the normal behavior of dead tips having the display saying "disconnected", and working ones displaying the temperature.
Thank you troisis.  It's not obvious this would happen, but when you explain it, it makes sense.
I guess I would call this post a good "tip".  See what I did there? Rolleyes
