Late to this, but in case it helps anyone landing here from search: the "printers disappear after the first job" pattern is usually cups-browsed/Avahi rather than the phone itself. The remote queues get discovered over mDNS, then dropped when the phone's Wi-Fi power saving makes it miss the next announcement.
What has worked for me on Mobian / Debian-based phones:
1. Use a permanent local queue instead of relying on discovered ones. With CUPS installed locally (as johnd described), add the printer once with a fixed URI, e.g.
sudo lpadmin -p office -E -v ipp://192.168.1.50/ipp/print -m everywhere
-m everywhere uses driverless IPP Everywhere, so no vendor driver is needed if the printer is AirPrint/IPP capable.
2. Make it the default, so command-line tools know where to send jobs:
lpoptions -d office and test with
lp -d office /usr/share/cups/data/testprint (or any PDF).
3. If you still want the Pi print server, point the phone straight at it instead of browsing:
ipp://<pi-address>:631/printers/<queue-name>, again with a fixed queue.
4. Give the printer a DHCP reservation on the router. Many home printers change address after sleep, which looks exactly like "found once, then gone". If it is a Canon and it keeps dropping off, the router-side steps in this guide on a
Canon printer keeps going offline apply to Linux clients too.
5. If Wi-Fi power saving is the culprit,
sudo iw dev wlan0 set power_save off (temporary) is a quick way to confirm it.
Evolution prints through GTK like the other apps, so once a fixed default queue exists it usually starts working as well.
