How to access GPS data in Mobian
Anyone know how to get the GPS information from the GPS in the PinePhone? I've tried a few programs to get the location but they all seem to go by IP address so they all basically just say the town I am in and are off by a few miles so I was hoping to get the actual information from the GPS itself but I don't know how to do that. I also tried 'whereami' and for some reason that doesn't work. I install it and it says I have the most up to date version then when I try to run `whereami` it says the package isn't installed.
You could install gpsd and run one of the clients. xgps works but is not optimized for the screen. The text based clients gpsmon and cgps will give you all the typical GPS statistical information. The NMEA output that gpsd needs is on /dev/ttyUSB1. The config file is in /etc/default/gpsd
The antenna is very weak and it will take a long time outdoors even with a clear view of the sky to get a lock. You will want to run the AGPS proof of concept script to speed up the initial lock. https://gist.github.com/alastair-dm/2632...e555fa6628
You can also talk directly to the modem via AT commands to get a location manually, It is what the AGPS script uses. https://sixfab.com/wp-content/uploads/20...l_V1.1.pdf
(05-08-2021, 08:52 PM)8bit Wrote: You could install gpsd and run one of the clients. xgps works but is not optimized for the screen. The text based clients gpsmon and cgps will give you all the typical GPS statistical information. The NMEA output that gpsd needs is on /dev/ttyUSB1. The config file is in /etc/default/gpsd
Thank you for the information! Quick question, as I don't have my PP on me right now to test, with the AGPS it says to run `AT+QGPS=1` to start the GPS, is that just ran in the command line? I don't have any real experience with working with modems in general though I do have experience with a handful of programming languages.
That would be through a serial terminal like minicom. If you run the AGPS script it turns GPS on for you so you don't need to do any manual AT commands.
If the AGPS script gives serial errors you probably need pyserial
sudo pip3 install pyserial
  Mobian MMS/SMS text problem bcnaz 16 35,290 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 996 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 61,529 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 69,416 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 2,914 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 326,273 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,616 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,547 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,236 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 3,997 04-29-2025, 02:10 PM
Last Post: mdk
