Failing to remove old gnome-authenticator
I did an 'apt-get remove gnome-authenticator' and then installed the flatpak version.
Now I have two identical "lock" icons on the desktop.  One brings up the flatpak version 4.x and the other brings up the 3.x version.
I can find no remnants of gnome-authenticator via apt-get or 'dpkg -l' and yet the icon and the program remain.
Any idea how to get rid of the 3.x version?
You could check the corresponding .desktop file in /usr/share/applications/, see which executable it points do and then look up the package ("dpkg -S $filename"). Or you could manually remove the old .desktop file to get rid of the icon.
Looking in /usr/share/applications for a .desktop file did not succeed. In fact I could not find a reference to either gnome-authenticator in there.
While dealing with a different issue I came across the 'list of application' in settings, which showed the duplicate authenticators also and suggested 'open in software'. So I did that and found myself at another list of applications. I selected 'Installed' and the two gnome authenticators showed there with little [x] buttons. They were basically indistinguishable other than by the size of the application, so I picked the smaller one size wise and tapped the [x]. It asked me to confirm and now the extra gnome-authenticator is gone from the desktop.
I also guessed right and the flatpak one is the one that remains.
  New camera app gnome-snapshot working on trixie? vusra 4 4,829 04-11-2025, 02:53 AM
Last Post: vusra
  gnome-control-center: segmentation fault on startup jojuma 4 5,889 09-12-2023, 08:49 AM
Last Post: jojuma
  Dist-upgrade and Chatty vs Gnome-Contacts biketool 9 11,696 09-30-2022, 08:53 PM
Last Post: treebeard
  Gnome Web CSS problem? jojuma 0 2,100 05-27-2022, 11:43 AM
Last Post: jojuma
  Change GUI from Phost to Gnome (or anything else) johnpine 0 2,229 05-27-2022, 06:52 AM
Last Post: johnpine
  Gnome-podcasts on Debian repos user641 4 7,263 02-06-2022, 04:58 AM
Last Post: jsch
  Gnome podcasts user641 0 2,215 01-03-2022, 06:56 PM
Last Post: user641
  Gnome podcasts user641 4 7,500 11-08-2021, 05:50 AM
Last Post: user641
  *urgent help*calls and gnome-conatcs gone after update user641 24 36,198 09-20-2021, 12:19 PM
Last Post: calinb
  remove lock screen unrealb2 0 2,078 09-18-2021, 12:42 AM
Last Post: unrealb2
