UFW (uncomplicated firewall) Start On Boot - Mobian (working)
Hey Ya'll,
Not entirely sure if others are wanting this, but thought I'd share my fix on this workaround if you been trying to get this firewall to start on system startup on mobian (fix will be similar to almost any Distro actually).
This is for anyone that wanted to use the UFW - uncomplicated firewall service vs iptables.
Useful background knowledge:
https://www.freedesktop.org/wiki/Softwar...orkTarget/
Assuming you have already installed ufw:
edit the /lib/systemd/system/ufw.service
sudo nano /lib/systemd/system/ufw.service
Comment or delete out any existing BEFORE and/or AFTER lines under [unit] and add the new conditions - should look similar to this:
[Unit]
Description=Uncomplicated firewall
Documentation=man:ufw(8)
DefaultDependencies=no
#Before=network.target
Before=network-pre.target
Wants=network-pre.target
Make sure you write out, save, and exit. What this does is makes sure the firewall starts BEFORE any network configuration. Which is the point of a firewall Smile
Add ufw.service to system startup
sudo systemctl enable ufw.service
Now also make sure ufw.conf has start on boot enabled (enabling just this without the above had no affect on startup). Edit the ufw.conf
sudo nano /etc/ufw/ufw.conf
ENABLED=yes
Write out and save and exit.
Reboot your phone. Once it is rebooted, head to terminal and check the firewall status:
sudo ufw status
Should be active on startup without having to manually enable it. This fix worked for me, hopefully it works for others - for anyone that also wants to use the ufw
(02-28-2021, 01:15 AM)theD0cto Wrote: Should be active on startup without having to manually enable it. This fix worked for me, hopefully it works for others - for anyone that also wants to use the ufw
Could you clarify what "fix" you actually have? (besides adapting the systemd unit to start the firewall potentially a little earlier). I installed ufw with "sudo apt install ufw" enabled it with "sudo ufw enable" and it simply gets run on start. So what was the issue before?
"sudo ufw enable" just enables the firewall to be active when you call it. It does not apply to automatically enabling the firewall on system reboot/startup. The ufw.conf was suppose to address this by editing the file to enable it on startup. systemctl enable adds the service to startup, but does not activate the firewall.
This is meant for:
- Adding ufw services to startup and automatically activating the firewall on system reboot so you do not have to "sudo ufw enable" through terminal anytime you had to reboot your phone.
If you google - ufw does not automatically start up on system reboot, you will see numerous instances of it not automatically starting even after editing the ufw.conf and adding it to startup services via systemctl.
So if you restart your phone, and it displays active after you enter "sudo ufw status"(without entering enable), cool, if not, and you want it to startup automatically and be active whenever you reboot your phone then this applies to you.
  Mobian MMS/SMS text problem bcnaz 16 39,288 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,774 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 68,803 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 73,617 10-08-2025, 06:21 AM
  New Install, apps start but don't show up on screen?! RT3 2 3,431 07-18-2025, 07:56 PM
  XLibre for Mobian Hiraghm 0 3,403 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 346,438 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 3,074 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 4,251 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 5,002 05-06-2025, 02:19 AM
