Remote access to Mate desktop using VNC
So I am trying to do the above and got everything working using X11vnx.  I get all the way to the point that the remote VNC viewer can view the Mate login screen.  This is when the problems occur.  I input the correct credentials and then the VNC session dies.  Below is a link to someone else who had a similar problem.
http://askubuntu.com/questions/288647/vn...alid-login
Now before I go and start trying to monkey with the system as described here (http://superuser.com/questions/524811/ho...spberry-pi), I want to see if anyone else has seen this and has a simple solution.  My four Raspberry Pis just work with VNC and so I am straying far from my comfort zone and general knowledge on this one.
I would love to know if anyone has addressed this situation successfully, and if so, how they did it.  If not, I will cross my fingers and try out the solution listed above although I am afraid that it might break other things....
Thank you!
JL
Well, I rebuilt the system and now everything works and so it must have something to do with the original install.  All is good now.
(05-09-2016, 07:35 PM)jl_678 Wrote: Well, I rebuilt the system and now everything works and so it must have something to do with the original install.  All is good now.
Glad to know :-)
  Install Telegram Desktop in KDE Neon podcastlinux 2 10,733 01-26-2020, 01:43 AM
Last Post: giga
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,941 04-16-2018, 03:09 PM
Last Post: Rocklobster
  After flashing Ubuntu- how to get graphical desktop Partymack711 6 17,910 02-01-2018, 09:45 AM
Last Post: Partymack711
Question HELP Ubuntu Mate password recovery procedure Captain Anni Hilator 5 15,651 08-03-2017, 03:52 PM
Last Post: Luke
  Recovering root access in Ubuntu Scientomancer 3 10,470 07-28-2017, 02:53 PM
Last Post: Scientomancer
  Error load mate desktop environment b.simp404 2 6,775 01-21-2017, 02:24 PM
Last Post: wizkidcom
  Installing Mate GSam 1 5,410 11-14-2016, 12:51 PM
Last Post: dkryder
  dual wifi, one as access point vigor 0 3,918 09-02-2016, 11:55 PM
Last Post: vigor
  Ubuntu images w Desktop + Utilities. Vidiot 7 16,393 08-07-2016, 06:01 PM
  straight boot into desktop Ola 2 6,645 08-01-2016, 11:12 PM
Last Post: Ola
