network on pine64+
I have a pine64 1gb. It works well... but the network card link light (green) blink. Is it a known bug in the driver or a problem with the card itself?
what image are you using?
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
It's this one from the wiki : Debian Linux Jessie with Mate GUI Image [20160508] by lenny.raposo with Longsleep kernel.
It had script to update uboot and the kernel to the latest version... They all updated fine.
Network does work, but normally the link light shouldn't blink... it gives the impression the cables is being constantly disconnected.
(05-08-2016, 07:09 AM)spz2k Wrote: It's this one from the wiki : Debian Linux Jessie with Mate GUI Image [20160508] by lenny.raposo with Longsleep kernel.
According to http://files.pine64.org/doc/datasheet/pi...et_1.6.pdf it looks as if the LED functions can be customized by altering registers. See page 43 top of page for what you are likely looking for.
A lot of this functionality is going to just be default setup as provided by Realtek
Interesting. Section 7.13 states default led configuration... to me it sounds like a defective network card. Default stated led 0 blinking on transmit and led 1 high or low depending on link state... connected or not... but on my card... both lights blinks randomly. The cable is fine... I used the old cable of my old server... wich hasn't been yet replaced by the pine64.
You may need to re-read that. My green led blinks in a slow steady fashion. Orange blinks with data.
  Programming languages support under PINE64 baryluk 6 18,414 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 9,458 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 33,541 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 5,950 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 8,933 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 49,587 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 4,471 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 12,847 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 5,107 12-09-2017, 08:14 AM
Last Post: incoherent
  Fedora Running On Pine64! cztian 26 54,009 10-26-2017, 05:51 PM
Last Post: gregjo
