Never ever mix up CPU board connector with 8-pin PCIE connector
Hello all,
 I just made a fatal mistake  Confused ! Here is the story.
I power up my rockpro64 boards with a ATX psu with a EPS12V to 8 DC barrel connectors. Until now no major problems. Then I decided to use a server power unit (which is common in the miner rigs domain why not use it for my boards ?) with a special adapter for PCIE (to power GPU cards) ... why not ?
The connectors are rather alike and I naively think that they are the same since they have the same function. Indeed we can plug them together.
When  I switched on ... sparks and flames ! Then I realized how stupid it was. The +12V and ground are inverted. It was simple though : 1st principle : connect the black wire with the black wire. I did not check, over confidence. Angry
So RIP my dear Rockpro64  Angel
"By chance" I just plugged one.
*If you are sensible do not watch the following pictures*
Is there a way to replace the components ?
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,324 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,983 08-14-2023, 07:55 AM
Last Post: kundanjha
  PCIE interface power on too late Slark Xiao 0 3,028 11-29-2022, 11:56 PM
Last Post: Slark Xiao
  Cannot get my board to boot deutschlmao 11 20,248 09-05-2022, 04:23 PM
Last Post: ljones
  PCIe gen1 timeout - how to debug tosi 3 10,272 03-10-2022, 05:06 PM
Last Post: db579
  Anyone try an NVIDIA GPU in the PCIe slot? Paraplegic Racehorse 0 3,424 04-15-2021, 11:46 AM
Last Post: Paraplegic Racehorse
  PCIe Armbian and Ayufan for nvme ssd LMM 1 5,262 02-03-2021, 04:38 PM
Last Post: LMM
  fan continously runs on kernel 5.8 but I need to use 5. kernel for PCIe sata card GreyLinux 4 10,258 10-20-2020, 10:52 AM
Last Post: GreyLinux
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 13,066 10-18-2020, 08:05 PM
Last Post: revoman
  4pin Connector for dual SATA m.ekstrom 4 10,354 07-28-2020, 07:07 AM
Last Post: mabs
