Volte and T-mobile
I have loaded many different Operating systems and while I can get ATT / Cricket to work well ,I have had no luck what so ever getting  any OS to recognize the T-mobile Sim. Tried loading atinout, modem manger and other software to no avail.  I am trying to avoid using the modem update software since I don't want to risk trashing the modem. Heck, flashing my Bio makes me nervous.  Has anyone found a way around my problem?
Check my post https://forum.pine64.org/showthread.php?...8#pid85368 for VoLTE settings / modem AT commands, it might help.
I don't have a SIM for an operator that has VoLTE enabled but you should be able to check for yourself (presuming the SIM works on VoLTE with another phone).
There is a "Commercial-TMO_VoLTE" profile in the modem so that would presumably be used automatically if VoLTE is enabled - you can also set it manually yourself.
Hope that helps.
There's also a thread for confirmed 4G VoLTE working here https://forum.pine64.org/showthread.php?tid=12560 if you get it to work. That should help, too.
  Mobile internet via cellular network mostly not working Anna 18 26,702 01-19-2024, 02:59 AM
Last Post: anonymous
  Block firefix-esr-mobile-config from (re)installing itself grump_fiddle_reinstall 3 5,392 01-07-2023, 09:36 AM
Last Post: dcarvil
Exclamation No modems were found: No mobile data, no 2G anonymous 2 4,892 12-26-2022, 06:46 PM
  very slow processing of MMS received via Ting (T-Mobile) treebeard 6 8,844 12-01-2022, 09:18 AM
Last Post: traut
  DNS Problems with Mobile Data arno_nuehm 29 40,274 10-29-2022, 09:16 AM
Last Post: treebeard
  Amberol Mobile Music player(flatpak) biketool 0 2,449 06-19-2022, 07:16 AM
  sharing mobile data through usb tethering deb75 7 10,594 02-26-2022, 08:52 AM
  Reskinning Apps for Mobile biketool 6 8,999 12-05-2021, 02:30 PM
  Mobile network mode setting not saved Zebulon Walton 3 6,405 12-05-2021, 12:12 AM
Last Post: bcnaz
  gnome podcasts on debian repo, dino-mobile user641 3 6,889 09-11-2021, 12:04 AM
Last Post: user641
