[WIP] Sailfish OS Alpha
#41
(11-17-2020, 04:05 AM)firefox-58 Wrote:
(11-17-2020, 12:41 AM)nicetux Wrote: Hi. I got yesterday a Pinebook Pro (white) and i am since i got my 'First One Jolla' a fan of SFOS. How can i support you? I want to help running SFOS on the Pinebook. Hint: I doesn't own any programming skills. Sad
My first thing what i want to do - i download me the image file and write them to a uSD card.
You have a
Pinebook
or a
PineBook Pro  ??
Its a Pinebook Pro (64GByte)
These builds are for the Pinetab not the Pinebook (the white one is a Pinebook) or Pinebook Pro
Not sure anyone has build one for the laptops yet. Also as they are very much touch focused not sure how useful it would be
1 Now with Pinephone Pro (used to have Pinephone and Pinetab) cooking on Mobian - Seasoned Ubuntu user since 2007
2 Known to break things - often
3 Sometimes known to fix things then see 2 above
Just a heads-up the image can be built with the flash-it script and one doesn't need my image anymore.
https://github.com/sailfish-on-dontbeevil/flash-it
Experience should be a tad better since the last image isn't very polished. However it seems browsers seem broken currently Sad
(12-19-2020, 02:29 AM)peperjohnny Wrote: Just a heads-up the image can be built with the flash-it script and one doesn't need my image anymore.
The flash.it script builds but still does not boot (no graphics but backlight keyboard works.....ie no text or screen)in the Pinetab I have. (Early adopter ubports). Is it building for a previous version?
Tried this before with same result. In fact flashit script only ever worked once ages ago pre alpha 2
Will try again later over the holidays
Pleased to report that I have now flashed this to the EMMC and it is working a treat especially now with the new kernel 5.10.
Great work.
(01-03-2021, 11:41 AM)andybleaden@gmail.com Wrote: Pleased to report that I have now flashed this to the EMMC and it is working a treat especially now with the new kernel 5.10.
Great work.
Good to know. Now  I can switch to SailfFishOS on the tablet
is OTA updating still broken? Wouldn't mind running an updated image to check out.
(01-04-2021, 02:59 PM)tophneal Wrote: is OTA updating still broken? Wouldn't mind running an updated image to check out.
Seems to work for updating although no updates since installation on mine yet
I did a quick :
devel-su
zypper ref
zypper up
With the browser not working and reliance on Webcat - accessing emails is a problem for now...you can see them not open them...the splash screen needs amending to be a quiet boot splash - other than that I am enjoying having it on my Pinetab again
I did a quick :
devel-su
zypper ref
zypper up
Is there a brief rundown, wiki, etc on the SailfishOS syntax?
This might be of help https://sailfishos.org/wiki/Sailfish_OS_Cheat_Sheet
Users browsing this thread: 18 Guest(s)
