Just got my Pinecil
Hey all.
I just got my Pinecil.  Immediately hooked it up to PD and tested it.  I'm impressed at how quickly it heats up given the wattage I allocated to it.  (I went into advanced settings and limited it to 15 watts, mostly to compare it to a similar-sized soldering pencil I had lying around.)  I did notice one thing odd though.  I didn't use it for very long (just long enough to dip the tip in some tinning compound and clean it), but the space around the "+" button seemed to get noticeably warm.  Not burning hot, mind you, but given that the housing is made out of plastic, it got warm enough to make me wonder how hot the components underneath were getting.  Anyone else noticed this?  Should I be concerned?
Eric
  Pinecil V2 + Raspberry Pi 5: Touchscreen-Controlled Soldering Station candera 0 93 10-08-2026, 03:26 AM
Last Post: candera
  Pinecil as a Pocket-Sized Wingman? Arsen 0 483 08-27-2026, 09:15 AM
Last Post: Arsen
  Question about firmware updates on Pinecil V2 helengrace 1 2,606 10-16-2025, 10:41 PM
  incorporate a multimeter into the Pinecil kellanphil 2 4,467 08-13-2025, 01:14 AM
Last Post: lalisa12
Lightbulb Pinecil -> Pinegun? Avamander 21 42,202 01-21-2025, 01:09 PM
  Will the Pinecil work for repairing iPods, in particular the 30pin port connector? drewdavis 0 1,879 08-27-2024, 08:01 PM
Last Post: drewdavis
Exclamation What is this - Pinecil V3? andrea6 2 17,167 12-19-2022, 08:11 PM
  on pinepower, pinecil stopped working.. sanderboer 1 3,649 09-23-2022, 03:47 AM
  Just got my Pinecil donwynne 1 3,784 04-22-2022, 07:01 AM
Last Post: bbeeast
  Pinecil Broken? skaaq 4 11,436 01-25-2021, 11:28 AM
Last Post: skaaq
