Just got my Pinecil
Hey all.
[color=#666666]I just got my Pinecil.  Immediately hooked it up to PD and tested it.  I'm impressed at how quickly it heats up given the wattage I allocated to it.  (I went into advanced settings and limited it to 15 watts, mostly to compare it to a similar-sized soldering pencil I had lying around.)  I did notice one thing odd though.  I didn't use it for very long (just long enough to dip the tip in some tinning compound and clean it), but the space around the "+" button seemed to get noticeably warm.  Not burning hot, mind you, but given that the housing is made out of plastic, it got warm enough to make me wonder how hot the components underneath were getting.  Anyone else noticed this?  Should I be concerned?
Don
(03-15-2022, 09:11 PM)donwynne Wrote: Hey all.
Don
Mine is  dead after using it for 3-4 times... crappy product
  Pinecil V2 + Raspberry Pi 5: Touchscreen-Controlled Soldering Station candera 1 502 10-12-2026, 09:42 PM
  Pinecil as a Pocket-Sized Wingman? Arsen 0 753 08-27-2026, 09:15 AM
Last Post: Arsen
  Question about firmware updates on Pinecil V2 helengrace 1 2,700 10-16-2025, 10:41 PM
  incorporate a multimeter into the Pinecil kellanphil 2 4,561 08-13-2025, 01:14 AM
Last Post: lalisa12
Lightbulb Pinecil -> Pinegun? Avamander 21 42,757 01-21-2025, 01:09 PM
  Will the Pinecil work for repairing iPods, in particular the 30pin port connector? drewdavis 0 1,913 08-27-2024, 08:01 PM
Last Post: drewdavis
Exclamation What is this - Pinecil V3? andrea6 2 17,340 12-19-2022, 08:11 PM
  on pinepower, pinecil stopped working.. sanderboer 1 3,700 09-23-2022, 03:47 AM
  Pinecil Broken? skaaq 4 11,506 01-25-2021, 11:28 AM
Last Post: skaaq
  Pinecil stuck in shipping? mbreese 3 8,696 01-07-2021, 07:46 AM
Last Post: moxx
