Possible to disable display of SMS text messages?
I'm sure I'm in a small minority but I don't like to be bothered by text messages. I don't want people sending them to me and don't want to be bothered by texts from my carrier, politicians, or other spammers. My flip phone does not automatically display texts, it merely puts a tiny icon up on its tiny screen to indicate their presence (no audio or vibrating alert is given) and I can go through the phone's menus to look at them if desired. SMS is working in my Mobian installation in testing but it's not something that I plan to use when going live with the Pinephone.
Is there a background daemon in Mobian that can be disabled so incoming text messages are not displayed? (I assume there's no way to stop receiving them since that capability is part of the modem - just not having them pop up on the screen would be sufficient.)
I've not spotted a way to do it, so you probably need to make a feature request upstream. I'd imagine it's the sort of thing people might want a setting for globally, for unknown numbers and on a per-contact basis. And all of these on a per-account basis since SMS is just a specific type of chat account. You can probably kill the daemonized instance of 'chatty', but that probably stops you getting any notification at all unless you write a replacement that listens for the dbus signals from ModemManager.
I think the daemonized chatty is started by /etc/xdg/autostart/sm.puri.Chatty-daemon.desktop
(12-08-2020, 12:12 PM)wibble Wrote: I've not spotted a way to do it, so you probably need to make a feature request upstream. I'd imagine it's the sort of thing people might want a setting for globally, for unknown numbers and on a per-contact basis. And all of these on a per-account basis since SMS is just a specific type of chat account. You can probably kill the daemonized instance of 'chatty', but that probably stops you getting any notification at all unless you write a replacement that listens for the dbus signals from ModemManager.
Interesting, thanks, I'll have to experiment with killing/disabling chatty and see how that works out.
  Disable vibrations 3x5co 9 12,659 01-03-2026, 12:26 PM
Last Post: baptx
  Mobian MMS/SMS text problem bcnaz 16 28,988 09-15-2025, 02:42 AM
Last Post: georgegohl888
  how to disable ipv6 at kernel level with towboot? vusra 3 3,516 10-04-2024, 04:23 AM
Last Post: vusra
  Delta Chat / text invisible chris_02 0 1,530 04-13-2023, 10:12 AM
Last Post: chris_02
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 4,079 02-24-2023, 12:11 AM
Last Post: nexion
  Mobian external display woes Hiraghm 5 5,832 12-09-2022, 12:12 PM
Last Post: gregb49
  Disable headphone controls 3x5co 0 1,680 09-10-2022, 07:11 AM
Last Post: 3x5co
  Unable to send messages with chatty user641 0 1,796 09-07-2022, 04:35 AM
Last Post: user641
  Chatty - XMPP receiving photos - inline display doesn't work arkadione 2 4,036 07-10-2022, 03:16 AM
Last Post: arkadione
  Disable *automatic* on-screen keyboard iwakura_lain 0 2,003 06-11-2022, 09:49 AM
Last Post: iwakura_lain
