Building a new cluster with external storage
I am contemplating building a new cluster and one of the questions I have asked myself is wether it would be better to boot all modules from a central server and rund them sort of "diskless" as I intend to build them into a K3S cluster anyway.
I could not find any clear reference to how this would need to be setup. I am not rookie as far as Linux is concerned. And at some point I have setup network boot with Sparc 4 hardware with RARP and TFTP. But I could not find a clear reference wether the sopine can do a net boot and what is required for it.
So if someone can show me pointers to information I might have missed out I can dig into it and see if I can work out a plan before I go and order things.
Regards, Hugo.
PS: I'll do my best to document all my steps online once I get going.
This is largely here be dragons territory. But this seems to be the starting point: https://github.com/janwillies/u-boot/releases
Edit: see also: https://forum.pine64.org/showthread.php?tid=5581
Great pointer. Thanks for that.
And an occasional dragon .... makes for a bit of fun.
Regards, Hugo.
  Buy Cluster and Compute Modules jpotter 1 5,398 01-10-2022, 04:01 PM
Last Post: dcdc
  What's the point of a cluster? guenther 2 7,847 04-07-2021, 10:49 AM
Last Post: guenther
  Add ordinary so-dimm memory to cluster slot? fxSol 1 6,363 03-02-2021, 03:54 AM
Last Post: poVoq
  Is my wooden desk a safe surface to test the cluster board on? ollehar 6 14,646 12-28-2020, 09:41 AM
Last Post: robocone
  Compatibility between RPi Module and Cluster board leperotero 1 5,909 11-03-2020, 03:40 PM
Last Post: poVoq
  Is there any way to get a video output from a cluster module? ollehar 4 11,108 06-16-2020, 12:34 PM
Last Post: ollehar
  What kind of box would be able to host both the cluster board and a RockPro64? ollehar 1 5,802 06-14-2020, 05:37 PM
  Compiling on the Sopine Cluster khaosgrille 3 9,223 08-10-2018, 06:17 AM
Last Post: khaosgrille
  Kubernetes on SoPine cluster part.1 maya.b 3 11,170 04-18-2018, 08:31 AM
Last Post: PigLover
  sopine cluster thermal images maya.b 4 11,291 12-29-2017, 02:51 PM
Last Post: Luke
