Backup user data and settings
Hi
As the system is changing constantly at the moment and I often update the image I am looking for a way to backup user data and settings
and restore them once the new image has booted or even before writing the image to the SD card.
E.g. how to backup and restore:
  • WiFi set up via the Posh UI
  • call logs
Thanks and regards
-kratz00
most user settings are stored in $HOME in hidden folders i.e. in $HOME/.config or $HOME/.share or etc
I believe networkmanager connections are stored in /etc/networkmanager/ but I could also be wrong
tar czf home_bak.tgz /home/<username>
sudo tar czf etc_bak.tgz /etc
tar xzf when you need them. 99% of the time works without issues, including encryption keys and passwords. The other 1% you are usually aware what the issues will be Smile
HTH
LF
Thanks for the feedback!
If I do not want to backup all of /etc and $HOME and need just need to identify the relevant files.
I will flash the OS to the internal eMMC and rsync the backup file to the microSD card.
After an image update I can just rsync them back and reboot.
Regards
-kratz00
If you are using rsync anyways, why not fetch the files directly via rsync instead of tarring them up first?
  Settings are reset after reboot lacriz 5 11,367 08-29-2023, 05:28 PM
Last Post: car46999
Question Always Use Mobile Data DingDangDoong 4 6,644 04-20-2023, 06:18 AM
Last Post: DingDangDoong
  The language I've added on settings doesn't appear Gon 2 4,751 08-15-2022, 01:55 PM
Last Post: Gon
  No Application Data PMOS 21.12.1 Captain1ndustry 4 8,744 08-12-2022, 07:42 AM
Last Post: Gon
  Disable mobile data auto-enable on boot 64_Tesseract 3 6,226 08-11-2022, 02:48 AM
Last Post: 64_Tesseract
  wwan0 (cellular data) ip configuration is POINTTOPOINT not BROADCAST dc2daylight 0 2,657 04-07-2022, 07:16 PM
Last Post: dc2daylight
  Calls don't work on Softbank. Cellular data & SMS work. yasmi 1 3,772 03-24-2022, 04:10 AM
Last Post: yasmi
  mobile data - always in use? someGermanGuy 13 24,941 04-03-2020, 02:32 PM
Last Post: janw
