Audio quality
Hi
Has any of the available distros for PinePhone fixed the poor audio quality yet? If so, which one(s)? Also, loudspeaker option if any of them has implemented it yet?
Cheers!
(10-23-2020, 08:19 AM)GloriousCoffee Wrote: Hi
Cheers!
Any distro with kernel 5.9 should have good call quality - Manjaro Beta 1 running 5.9 sounds really good to my ear.
If kernel 5.9 is all that's needed, you should try multi-boot image with 13 operating systems, all on this kernel: https://forum.pine64.org/showthread.php?tid=11347.
Hm, looking at manjaro.org I only see distro for PineBook. Where might I find image for Manjaro with kernel 5.9?
Cheers!
(10-23-2020, 09:13 AM)fsflover Wrote: If kernel 5.9 is all that's needed, you should try multi-boot image with 13 operating systems, all on this kernel: https://forum.pine64.org/showthread.php?tid=11347.
Does the multi-boot support FDE?
(10-24-2020, 07:38 AM)GloriousCoffee Wrote: Hm, looking at manjaro.org I only see distro for PineBook. Where might I find image for Manjaro with kernel 5.9?
https://forum.manjaro.org/t/manjaro-arm-...hone/32307
https://osdn.net/projects/manjaro-arm/st...osh/beta1/
Thank you
It says kernel 5.7, do I need to update it manually? Are there any update manager in Manjaro for PinePhone or is this done through terminal?
  How to play audio from ffmpeg? Manieck71 10 14,528 08-31-2023, 03:02 AM
Last Post: Manieck71
  Modem audio settings jack1 2 4,123 02-04-2023, 04:01 PM
Last Post: jack1
  3.5mm jack audio quality? orbital 3 7,113 06-27-2022, 02:05 AM
Last Post: wibble
  scratchy phone audio KABA 3 6,368 06-24-2021, 01:15 PM
Last Post: jameslauren11
  poor call quality try flipping switch six D4rkh0rs3 0 2,715 05-12-2021, 12:09 PM
Last Post: D4rkh0rs3
  Phone Calling - Extremely Bad Quality mischmerz 5 10,298 09-21-2020, 04:37 AM
Last Post: SwordfishII
