No modem
Hello there,
I have my pinephone for less than 15 days now.
I played for some days then stopped...
I tried to use it again today but on Mobian "mmcli -L" gives me "No modem were found".
So I decided to go for the factory image.
When I start the modem test I have "Boot timeout".
Is my modem broken ?
All the pins are up by the way...
Thank you,
Taz
Try toggling the switch with the phone off just in case there's a contact issue there. Does the modem show up in lsusb? This is what I see:
mobian@mobian:~$ lsusb
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 002: ID 2c7c:0125 Quectel Wireless Solutions Co., Ltd. EC25 LTE modem
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bug PinePhone modem keeps "disappearing" Kevin Kofler 21 24,035 09-11-2026, 09:18 AM
Last Post: idice
  Modem Issues with the Pinephone Temmie19 5 7,306 07-02-2025, 12:50 PM
  FOSS fw problem - PinePhonePro, EG25 modem dukla2000 5 7,084 02-05-2025, 02:30 AM
  Supported Carrier and Modem Bands NachoMomma 4 9,429 03-23-2024, 02:00 PM
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 5,442 02-17-2024, 04:15 PM
Last Post: vortex
  modem not working michelinux 0 2,705 02-16-2023, 04:56 AM
Last Post: michelinux
  modem not detected al_x 3 9,399 02-15-2023, 11:17 AM
Last Post: fxc
  firmware udate Quectel EG25-G modem alwi 7 16,163 07-06-2022, 01:43 PM
Last Post: user641
  Need command to tell what modem firmware I am on. purpletiger 4 8,605 07-06-2022, 12:35 PM
  The modem does not recognize Korean SIM cards (what?) bdicewk 9 12,474 06-13-2022, 04:12 AM
Last Post: zetabeta
