Screen shuts off when convergence dock plugged in
PostmarketOS convergence edition phone. Software fully up to date. Plugging in the dock shuts off the screen immediately, no matter what is in (or not in) the dock, even if it's empty. Unplugging it immediately restores the display.
When plugging in a basic 4-port USB3 to type C hub I had laying around, the screen dims significantly. Thinking perhaps the screen shuts off when power draw is too high I plugged an LED keyboard into that USB hub, but screen brightness did not change, the keyboard just lit for a moment then shut off.
This turned out to be an issue related to the backlight voltage rail / data bus issue, you just have to set the backlight to at least 50% brightness before plugging in a USB device.
The USB device also doesn't always work, but that seems to be somewhat a matter of luck
  PinePhone Dock with laptop? Mikey1977Y2J 2 4,804 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Convergence package USB-C Docking Bar for Wired Ethernet (part II) Peter Gamma 4 6,528 10-08-2023, 11:49 PM
Last Post: zetabeta
  Pinephone Pro Convergence Dock Ethernet performance with non-pro pinephone Matt2020 10 15,300 03-07-2023, 12:33 PM
Last Post: emsyr
  PinePhone convergence docking bar malfunctioning bircoph 3 6,210 12-09-2022, 05:41 PM
Last Post: bircoph
  A Pinephone case that'll actually prevent the screen from cracking mil 24 37,847 11-18-2022, 02:18 PM
Last Post: mil
  Convergence docking bar and keyboard pifou 4 8,509 06-23-2022, 04:40 AM
Last Post: wibble
  The PinePhone USB-C dock of the magician Martijn Braa Peter Gamma 0 2,504 06-12-2022, 08:24 AM
Last Post: Peter Gamma
Question Keyboard Case + Convergence Dock Merc 5 8,165 04-21-2022, 10:24 AM
Last Post: zetabeta
  Convergance Dock HDMI resolution: bceverly 4 7,992 03-09-2022, 12:41 PM
Last Post: alxtrnr
  Screen/Screen Protector Whitening Issue adjf873_n-s 6 11,111 03-09-2022, 02:46 AM
Last Post: adjf873_n-s
