Plasma-wayland on Manjaro
In my quest to get redshift working, or an alternative, I installed and started keeping tabs on the performance of Wayland. It was unsurprisingly hard to use, being very choppy, at first. After the latest post 19.06 updates something borked my xorg plasma session and started boot looping. On a whim to get to the desktop I selected a Wayland session, and it not only got me in, but its running fairly well, with noticeable improvements. The performance even feels better than with xorg. Night color works well, with some slight choppiness while transitioning temperatures. I have a feeling not many people thought to try running Wayland on the Pinebook, so I figured Id let it be known, its actually worth it now.
Hi top.   I've been following the panfrost dev work and it's still not ready for Plasma wayland on my new N2+ board.   Works kinda ok on my rock64 with mali 450.     Maybe soon since the C4 has a similar gpu and its working.   Not sure how well.  In the meantime I use odroid Ubu 20 Gnome-wayland which uses the libmali drivers.   So it can do it. The free driver is just not there yet.
Curious if the rockpro can run it.
(09-01-2020, 12:21 AM)tomarm Wrote: Hi top.   I've been following the panfrost dev work and it's still not ready for Plasma wayland on my new N2+ board.   Works kinda ok on my rock64 with mali 450.     Maybe soon since the C4 has a similar gpu and its working.   Not sure how well.  In the meantime I use odroid Ubu 20 Gnome-wayland which uses the libmali drivers.   So it can do it. The free driver is just not there yet.
Yes, the RockPro64 should be able to run it. It works well on the PBP, each of my OS options for mine uses Gnome+Wayland by default.
Information Manjaro ARM for Pinebook erchache2000 88 186,871 11-29-2020, 04:36 PM
Last Post: Mr.Fermer
  Manjaro sway profile for pinebook e-minguez 3 10,130 07-21-2020, 03:25 PM
Last Post: jezek
  Manjaro instability DAMO238 6 15,194 10-17-2019, 12:55 PM
  Manjaro hangs on boot DAMO238 1 5,756 07-08-2019, 08:14 AM
Last Post: DAMO238
  manjaro and qemmu+kvm erchache2000 2 7,324 06-11-2019, 03:11 AM
Last Post: Skywheel
  Netflix on KDE Plasma SoccerCrazed 0 3,630 11-16-2018, 10:11 AM
Last Post: SoccerCrazed
  Dimmed screen too much in plasma boballen55 1 5,655 11-09-2018, 03:42 PM
Last Post: boballen55
