Announcing the Mobian project
I used the August 23 release all day, over-all it worked pretty well.
One time (of many successful uses) it would not open after suspend, had to do hard shut down and restart.
One time while writing a sms/text message it went to the log-in page.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
August 24 release :
  NO SOUND  !
  I put the August 23 sd card back in and still no sound  ?
I then reflashed the August 23 sd card and everything seems ok now.
         Huh
(08-24-2020, 07:11 AM)bcnaz Wrote: August 24 release :
  NO SOUND  !
         Huh
no reflashe, the libasound2 downgrade fixed this problem : https://gitlab.com/mobian1/issues/-/issues/78
Is there a way to switch off CRUST?
The other day I was calling the phone and it started to wake up, but didn't finish until the ringing stopped and there was no notification of a missed call. I think this deep sleep stuff is missing the point here.
(08-26-2020, 01:28 AM)cefre00 Wrote: Is there a way to switch off CRUST?
Go to settings --> power, at the bottom you can set if and when it goes to standby.
Thank you, good stuff. Wink
Strange, With the August 30 nightly I can receive calls, but I cannot call out ? .. ?
(08-30-2020, 07:41 AM)bcnaz Wrote: Strange,  With the August 30 nightly I can receive calls, but I cannot call out ? .. ?
Same here. Which carrier do you have ?
I am on AT&T in USA,  Arizona...
I test the nightly builds.
But I have a build on one sd card I save, (August 26, I think) that I can use, that works for most functions.
August 31 appears to be ok,
it was a little laggy at first, and the first wake up was not promising,
but I just received my DHL shipper notification on the sms/text app, regarding my
PMOS Convergence phone.
 A few power cycles, phone calls, and texts,  now that release seems "OK"
NOTE:
It helps to have plenty of sd cards.
When you get a good working system, save that card .. !
Use different old or failed system cards to download the new 'to be tested' systems.
Then you can go back to a working system if you need it.
During the daytime I do use my Brave Heart phone,     " as a phone "
In the evenings I do my testing of new releases, and systems.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 70 30,997 59 minutes ago
Last Post: anonymous
  Mobian MMS/SMS text problem bcnaz 16 23,728 09-15-2025, 02:42 AM
Last Post: georgegohl888
  cryptocurrency on mobian/pinephone biketool 33 54,701 06-30-2025, 02:57 PM
  XLibre for Mobian Hiraghm 1 1,607 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 259,230 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 1,424 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 1,793 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 2,184 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 2,242 04-29-2025, 02:10 PM
Last Post: mdk
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 2,363 01-15-2025, 08:08 PM
