pmbootstrap build large keyboard not usable
I have done two builds using a Manjaro distro with pmbootstrap and they both resulted in a bootable image that had a gigantic keyboard that went off the screen and was not usable.
Is this a new issue, or possibly some issue created by building it with Manjaro?
Distributor ID: ManjaroLinux
Description: Manjaro Linux
Release: 20.0.3
Codename: Lysia
Linux linux-ThinkPad 5.6.16-1-MANJARO #1 SMP PREEMPT Wed Jun 3 14:26:28 UTC 2020 x86_64 GNU/Linux
(07-19-2020, 08:43 PM)u20200719 Wrote: I have done two builds using a Manjaro distro with pmbootstrap and they both resulted in a bootable image that had a gigantic keyboard that went off the screen and was not usable.
Release: 20.0.3
Codename: Lysia
The large keyboard seems to be gone after upgrading to pmbootstrap 1.22.0.  Now only the applications go off the screen.
Build steps:
https://pastebin.com/z01umbp9
Large scale applications:
http://www.filedropper.com/postmarketospmbootstrapbig
You're probably using the edge branch and Phosh. Most of the applications going off screen are fixed on the stable branch, so please use that instead.
(07-22-2020, 03:25 PM)PureTryOut Wrote: You're probably using the edge branch and Phosh. Most of the applications going off screen are fixed on the stable branch, so please use that instead.
Thanks, I rebuilt with stable and it is now working.  I was using edge.
EDIT: Changed not to now.
"it is not working", what is "it"? Are you absolutely sure you're using the stable branch, could you post the contents of /etc/apk/repositories?
(07-25-2020, 02:05 PM)PureTryOut Wrote: "it is not working", what is "it"? Are you absolutely sure you're using the stable branch, could you post the contents of /etc/apk/repositories?
Apologies for the typo.  It does work now, thank you.
  Bluetooth keyboard paired to PostmarkedOS disconnect Peter Gamma 2 5,777 10-21-2023, 12:32 AM
Last Post: Peter Gamma
  Physical keyboard symbols not working again vgnmnky 3 6,367 10-28-2022, 12:56 AM
Last Post: theResonant
  Pinephone Keyboard Utilities on postmarketOS elof 2 7,015 06-20-2022, 01:33 PM
Last Post: elof
  Chromium now usable with a patch jmorris 5 9,288 06-14-2022, 03:24 AM
  Latest build no firefox, text editor? cosmicschock 2 4,915 10-03-2021, 12:19 PM
Last Post: cosmicschock
  Build signal-cli uby89 2 8,432 07-25-2021, 10:23 AM
Last Post: uby89
Wink Extremely fast pmOS build for the pinephone lucasanss 0 5,425 02-03-2021, 04:05 PM
Last Post: lucasanss
  pmbootstrap error lat 2 8,011 12-22-2020, 06:32 PM
Last Post: lat
  Build state today firefox-58 3 8,487 10-24-2020, 08:48 AM
Last Post: jmorris
  pmbootstrap issues IVp 3 10,409 09-24-2020, 02:24 AM
Last Post: Pinethom
