Stuck on login screen
Every time I try to login I just get kicked back to the login screen. How do I fix this?
There's a lot of necessary information missing for anyone to be able to help you meaningfully.
What device are you using? And, what OS is it booting?
Something tells me it's a Pinebook Pro.
Sounds like the desktop session is dying while it's trying to start up. Hit Ctrl+Alt+F1 to switch to a virtual terminal and see if you can log in on console. (Ctrl+Alt+F7 to go back to X11, i.e. the desktop.)
Read through the various log files in /var/log/. Find the lines marked with the time of your login attempt, one or more of the files will likely report what's dying.
Also, have you used this PBP before? If so, try to remember what you changed last time you were on.
  Second screen mirroring Fanche35 3 1,888 11-17-2025, 01:06 AM
Last Post: andrekyler
  PinePower 120W Screen Issues t-3 3 3,921 09-26-2022, 05:14 PM
Last Post: superkamiguru
  onscreen keyboard, screen locker and other tools(X) moved ! jack1 0 1,922 08-10-2021, 03:19 PM
Last Post: jack1
  Ugm, stuck in a loop dgdimick 2 4,881 03-19-2021, 05:42 AM
Last Post: dgdimick
  Pinecil stuck in shipping? mbreese 3 7,110 01-07-2021, 07:46 AM
Last Post: moxx
  smlock minimal screen locker jack1 0 2,501 11-28-2020, 05:03 PM
Last Post: jack1
  PineTime Dev Kits stuck in SHENZHEN LinPhoneDev 0 4,778 08-25-2020, 10:38 AM
Last Post: LinPhoneDev
  touch screen panel question diggledorf 1 4,182 08-23-2020, 06:09 PM
  Forum Login Failure neilman 3 8,873 11-07-2019, 12:07 PM
  Forum login problems with Chromebook jiyong 4 8,074 08-09-2019, 04:36 AM
Last Post: jiyong
