04-19-2016, 10:32 AM
I'd like to hear from someone who didn't want the switch on the Pine. That's the reason the switches weren't pre-soldered.
If I've helped you with something, please leave a rating for my responses.
Switch found in the box
04-19-2016, 12:00 PM
(04-19-2016, 10:35 AM)tkaiser Wrote:(04-19-2016, 10:10 AM)CaptainZalo Wrote: I'll rather attach some pins I seriously need to read up on all the connections on the Pine. You've just made part of my day.
04-19-2016, 07:48 PM
Got my Pine today - the Pine was in a bag, in a box, in an envelope, sealed. There was also what seems to be a small button -- for rebooting? How and where do I attach it to the board?
04-20-2016, 08:55 AM
It can be used as a power switch, or as a reset switch. You can put the switch into the four-hole pattern found below the USB ports in this image: http://wiki.pine64.org/images/7/7d/Pine6...nector.png
You don't have to solder the switch onto the board, you can just bend the switch connectors inside the holes. Soldering would guarantee a good connection though.
04-20-2016, 11:57 AM
(04-03-2016, 02:10 PM)pine.adam Wrote: I received my pine the other day. 2gb version. Mine was loose outside the box in the mailer.
04-21-2016, 09:01 AM
I had a dream about that little power button the other night...
04-21-2016, 09:41 AM
(04-21-2016, 09:01 AM)psychedup Wrote: I had a dream about that little power button the other night... Was it about diving into a sea of teeny tiny tact switches? I have had that dream, my friend... Or maybe you took the switch out for dinner then dancing? I have had that dream too... Hopefully it's not a nightmare......
04-21-2016, 03:55 PM
I'm still waiting for my pine64's to ship, but I have received a couple of things from Amazon this week in padded envelopes. The other night I woke up in a panic because that button might still be in the envelope!
04-23-2016, 10:21 PM
Mine was loose in the mailing container. Freaked out a bit when I saw it =)
| Power Switch for Pine64 512MB Board | MonarchOfLight | 0 | 3,643 |
10-24-2016, 04:33 PM Last Post: MonarchOfLight |
| Script Not Found error using PhoenixCard | Ghost | 4 | 25,866 |
07-16-2016, 08:01 PM Last Post: Ghost |
