connector type SPDIF FAN RTC battery?
I'm trying to find a plug for the SPDIF connector, but didn't find any information about it's type/name.
Does anybody know what I'd have to search for if I'd want to find a plug that fits?
(03-12-2020, 04:15 PM)ChriChri Wrote: I'm trying to find a plug for the SPDIF connector, but didn't find any information about it's type/name.
Nobody here who can help me to find a plug for the SPDIF connector?
I am not quite sure what exactly your intentions are with the SPDIF connector but I am dropping a link below that may help.  Most of the adapters I have found use a 4 pin connector, but this kit includes a 3 pin option that should fit, but it may require minor modifications to wok.  Give it a look and see what you think.
https://www.ebay.com/i/182484182912?chn=...DUEALw_wcB
https://forum.pine64.org/showthread.php?...6#pid62336
look at for example link.
Thanks! That has been exactly what I'd been looking for: JST PHR-3 (or PHR-2 for fan and rtc). It would be great if this would end up in the wiki: If people want to connect to these connectors and Pine64 ist not offering the parts it is a great help to know what to look for!
  ROCKPro64 Battery Power Supply hoarfrosty 12 14,851 04-01-2024, 10:24 PM
Last Post: nano2
Question RockPro64 Lithium Battery Port TitleOS 0 3,371 12-05-2020, 12:35 AM
Last Post: TitleOS
  How do you connect PWM fan (3/4 pins) to this board (2 pin fan connector)? aleksei 3 12,501 11-19-2020, 04:35 PM
Last Post: Gienek
  SPDIF to TOSLINK zener 12 30,897 04-08-2020, 07:17 AM
Last Post: ChriChri
  Rockpro64 12v Lipo battery for playbox? ScrumpyJack 0 3,252 09-18-2019, 01:25 AM
Last Post: ScrumpyJack
  Battery Powered Firesped 17 34,119 08-02-2019, 07:56 AM
Last Post: ender_saved
  Fan connector pc2005 2 7,318 06-23-2019, 02:13 PM
Last Post: pc2005
  USB 3 type-C port Thunderbolt compatible? mscdex 1 5,058 06-20-2019, 10:55 AM
Last Post: Tim Jones
  SPDIF optical cable? zener 1 4,709 12-24-2018, 09:52 PM
  MIPI CSI connector and FPC hitmantj 1 5,427 07-06-2018, 03:42 PM
Last Post: Bullet64
