Where are the HW kill switches located?
a slot cut out where the hw dip switches are and a rubber cover would fix the issue ...
that way the back cover doesnt need to constantly be removed and the dip switches can be easily accessed ...
[Image: s-l300.jpg]
Something like this that are usually covering micro sd slots on devices.
(02-15-2020, 12:12 AM)iamcheese Wrote: a slot cut out where the hw dip switches are and a rubber cover would fix the issue ...
[Image: s-l300.jpg]
Yes. this is a great idea.
I will definitely grab a 3d printer when someone releases a design for one.
I understand pine not considering it a priority though.
  Kill switches for Wifi/Bluetooth does not work luxgiammi 0 3,163 10-14-2024, 03:34 PM
Last Post: luxgiammi
  USB-C CC pins are pulled to the GND by AW3512 (VCONN switches) when VCONN is off fsflover 41 88,115 06-17-2021, 04:54 PM
Last Post: feklee
  Is the PinePhone only Pine-device with hardware switches? harrm 1 4,613 01-23-2021, 12:29 AM
  Only enable modem when needed with kill switches sokolgeo 2 8,365 09-20-2020, 04:40 AM
Last Post: sokolgeo
  hardware switch wishlist/discussion - switches on the outside? mypine 7 12,997 04-12-2020, 10:40 AM
Last Post: wibble
  Kill switches blicken 2 6,655 02-08-2020, 03:51 PM
Last Post: wibble
