pmbootstrap to sdcard
Hi, last night i tried to install pmOS (plasma mobile extra) from pmbootstrap, but i recieved an error message:
Quote:(024312) [21:53:28] (native) % mkdir -p /mnt/install/boot
(024312) [21:53:29] (native) % mount /dev/installp1 /mnt/install/boot
mount: /mnt/install/boot: wrong fs type, bad option, bad superblock on /dev/installp1, missing codepage or helper program, or other error.
(024312) [21:53:34] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
I tried the demo image and it's ok but how can i make the pmbootstrap work?
(02-09-2020, 06:44 AM)albertz Wrote: Hi, last night i tried to install pmOS (plasma mobile extra) from pmbootstrap, but i recieved an error message:
if you want to install on SD card, you shoudn't run
pmbootstrap install --sdcard /dev/mmcblk0
but pmbootstrap install --sdcard=/dev/sd*, where * can be a,b,c... for instance :
pmbootstrap install --sdcard=/dev/sdb
because mmcblk() is the emmc module, when sd() (for instance sdb, sdc..) is a SD card. Make sure you identifiy well your SD card. You may run :
ls /dev/
before inserting you SD card, and after, to see what is the name of the device. In my case, it is sdb, but for you, it can be something else.
* PinePhone BraveHeart Edition
I think some clarification of device naming may be needed. Whether an DS card appears as /dev/sdX or /dev/mmcblkX depends on whether it's attached through a USB adapter or a native interface. For a native interface like in the PinePhone, boards such as the Raspberry Pi, or some laptops, the SD card appears as /dev/mmcblkX. A USB adapter translates between native interface commands and USB storage device commands, so the computer sees a usb storage device /dev/sdX. If you look at dmesg immediately after plugging in the card you should see which device was added.
(02-10-2020, 02:48 AM)Gobelin Wrote: if you want to install on SD card, you shoudn't run
ls /dev/
but I've used lsblk to identify the media, I think is not a problem of the localization of the media but from some internal of pmbootstrap or some misconfiguration during the init, but i I don't know. If i want to restart the installation i have to use pmbootstrap zap?
I've tried again but there is something with the partition, here the log:
(013263) [15:34:19] (native) partition /dev/install (boot: 69M, root: the rest)
(013263) [15:34:19] (native) % parted -s /dev/install mktable msdos
Error: I/O error during write on /dev/install
(013263) [15:34:21] (native) % parted -s /dev/install mkpart primary ext2 2048s 69M
Error: /dev/install: unrecognised disk label
(013263) [15:34:26] (native) % parted -s /dev/install mkpart primary 69M 100%
(013263) [15:34:32] (native) % parted -s /dev/install set 1 boot on
(013263) [15:34:37] NOTE: (1/20) failed to find the install partition. Retrying...
(013263) [15:34:37] NOTE: (2/20) failed to find the install partition. Retrying...
(013263) [15:34:37] NOTE: (3/20) failed to find the install partition. Retrying...
(013263) [15:34:37] NOTE: (4/20) failed to find the install partition. Retrying...
(013263) [15:34:37] NOTE: (5/20) failed to find the install partition. Retrying...
(013263) [15:34:37] NOTE: (6/20) failed to find the install partition. Retrying...
(013263) [15:34:37] NOTE: (7/20) failed to find the install partition. Retrying...
(013263) [15:34:37] NOTE: (8/20) failed to find the install partition. Retrying...
(013263) [15:34:37] NOTE: (9/20) failed to find the install partition. Retrying...
(013263) [15:34:38] NOTE: (10/20) failed to find the install partition. Retrying...
(013263) [15:34:38] NOTE: (11/20) failed to find the install partition. Retrying...
(013263) [15:34:38] NOTE: (12/20) failed to find the install partition. Retrying...
(013263) [15:34:38] NOTE: (13/20) failed to find the install partition. Retrying...
(013263) [15:34:38] NOTE: (14/20) failed to find the install partition. Retrying...
(013263) [15:34:38] NOTE: (15/20) failed to find the install partition. Retrying...
(013263) [15:34:38] NOTE: (16/20) failed to find the install partition. Retrying...
(013263) [15:34:38] NOTE: (17/20) failed to find the install partition. Retrying...
(013263) [15:34:38] NOTE: (18/20) failed to find the install partition. Retrying...
(013263) [15:34:38] NOTE: (19/20) failed to find the install partition. Retrying...
(013263) [15:34:39] NOTE: (20/20) failed to find the install partition. Retrying...
(013263) [15:34:39] ERROR: Unable to find the partition prefix, expected the first partition of /dev/mmcblk0 to be located at /dev/mmcblk01 or /dev/mmcblk0p1!
(013263) [15:34:39] See also: <https://postmarketos.org/troubleshooting>
(013263) [15:34:39] Traceback (most recent call last):
 File "/home/albertzdic/.local/lib/python3.7/site-packages/pmb/__init__.py", line 63, in main
   getattr(frontend, args.action)(args)
 File "/home/albertzdic/.local/lib/python3.7/site-packages/pmb/helpers/frontend.py", line 196, in install
   pmb.install.install(args)
 File "/home/albertzdic/.local/lib/python3.7/site-packages/pmb/install/_install.py", line 547, in install
   install_system_image(args)
 File "/home/albertzdic/.local/lib/python3.7/site-packages/pmb/install/_install.py", line 397, in install_system_image
   pmb.install.partitions_mount(args)
 File "/home/albertzdic/.local/lib/python3.7/site-packages/pmb/install/partition.py", line 52, in partitions_mount
   "1 or " + prefix + "p1!")
RuntimeError: Unable to find the partition prefix, expected the first partition of /dev/mmcblk0 to be located at /dev/mmcblk01 or /dev/mmcblk0p1!
this error don't understand (this from a log from 2nd time try):
now i tried to mklabel gpt directly with parted but gives me error
(parted) mklabel gpt
Error: Input/output error during write on /dev/mmcblk0
can it be the the sd itself?
Ok it was the sd,  i've bought a new sd and the pmbootstrap was successful. It was strange, because dd a demo image with the old sd was ok... Huh
Hello. Here's what I get from the install to the sdcard:
curt@pop-os:~$ pmbootstrap install --sdcard /dev/mmcblk0
[14:16:09] *** (1/5) PREPARE NATIVE CHROOT ***
[14:16:09] (native) install alpine-base
[14:16:10] NOTE: Valid pkgvers are described here:
[14:16:10] <https://wiki.alpinelinux.org/wiki/APKBUILD_Reference#pkgver>
[14:16:10] ERROR: Invalid pkgver '3.x.x' in APKBUILD: /home/curt/.local/var/pmbootstrap/cache_git/pmaports/device/linux-pin64-pinephone/APKBUILD
[14:16:10] See also: <https://postmarketos.org/troubleshooting>
Run 'pmbootstrap log' for details.
So, here's output from 'pmbootstrap log':
curt@pop-os:~$ cat pmbootstrap.log
(5/19) Installing alpine-conf (3.8.3-r6)
(6/19) Installing libcrypto1.1 (1.1.1d-r4)
(7/19) Installing libssl1.1 (1.1.1d-r4)
(8/19) Installing ca-certificates-cacert (20191127-r1)
(9/19) Installing libtls-standalone (2.9.1-r0)
(10/19) Installing ssl_client (1.31.1-r11)
(11/19) Installing zlib (1.2.11-r3)
(12/19) Installing apk-tools (2.10.4-r3)
(13/19) Installing busybox-suid (1.31.1-r11)
(14/19) Installing busybox-initscripts (3.2-r2)
Executing busybox-initscripts-3.2-r2.post-install
(15/19) Installing scanelf (1.2.4-r0)
(16/19) Installing musl-utils (1.1.24-r0)
(17/19) Installing libc-utils (0.7.2-r0)
(18/19) Installing alpine-keys (2.1-r2)
(19/19) Installing alpine-base (3.12_alpha20200122-r0)
Executing busybox-1.31.1-r11.trigger
OK: 8 MiB in 19 packages
(027632) [14:16:10] (native) % adduser -D pmos -u 12345
(027632) [14:16:10] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap-abuild-config /home/pmos/.abuild
(027632) [14:16:10] (native) % chown pmos:pmos /mnt/pmbootstrap-abuild-config
(027632) [14:16:10] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap-ccache /home/pmos/.ccache
(027632) [14:16:10] (native) % chown pmos:pmos /mnt/pmbootstrap-ccache
(027632) [14:16:10] (native) % busybox su pmos -c HOME=/home/pmos mkdir -p /home/pmos/packages
(027632) [14:16:10] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap-packages /home/pmos/packages/pmos
(027632) [14:16:10] (native) % chown pmos:pmos /mnt/pmbootstrap-packages
(027632) [14:16:10] (native) % busybox su pmos -c HOME=/home/pmos mkdir -p /home/pmos/.cargo/registry
(027632) [14:16:10] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap-rust/registry/index /home/pmos/.cargo/registry/index
(027632) [14:16:10] (native) % chown pmos:pmos /mnt/pmbootstrap-rust/registry/index
(027632) [14:16:10] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap-rust/registry/cache /home/pmos/.cargo/registry/cache
(027632) [14:16:10] (native) % chown pmos:pmos /mnt/pmbootstrap-rust/registry/cache
(027632) [14:16:10] (native) % busybox su pmos -c HOME=/home/pmos mkdir -p /home/pmos/.cargo/git
(027632) [14:16:10] (native) % busybox su pmos -c HOME=/home/pmos ln -s /mnt/pmbootstrap-rust/git/db /home/pmos/.cargo/git/db
(027632) [14:16:10] (native) % chown pmos:pmos /mnt/pmbootstrap-rust/git/db
(027632) [14:16:10] (native) calculate depends of cryptsetup, util-linux, e2fsprogs, parted, dosfstools (pmbootstrap -v for details)
(027632) [14:16:10] NOTE: Valid pkgvers are described here:
(027632) [14:16:10] <https://wiki.alpinelinux.org/wiki/APKBUILD_Reference#pkgver>
(027632) [14:16:10] ERROR: Invalid pkgver '3.x.x' in APKBUILD: /home/curt/.local/var/pmbootstrap/cache_git/pmaports/device/linux-pin64-pinephone/APKBUILD
(027632) [14:16:10] See also: <https://postmarketos.org/troubleshooting>
(027632) [14:16:10] Traceback (most recent call last):
File "/home/curt/pmbootstrap/pmb/__init__.py", line 63, in main
File "/home/curt/pmbootstrap/pmb/helpers/frontend.py", line 198, in install
File "/home/curt/pmbootstrap/pmb/install/_install.py", line 493, in install
build=False)
File "/home/curt/pmbootstrap/pmb/chroot/apk.py", line 202, in install
packages_with_depends = pmb.parse.depends.recurse(args, packages, suffix)
File "/home/curt/pmbootstrap/pmb/parse/depends.py", line 146, in recurse
package = package_from_aports(args, pkgname_depend)
File "/home/curt/pmbootstrap/pmb/parse/depends.py", line 33, in package_from_aports
aport = pmb.helpers.pmaports.find(args, pkgname_depend, False)
File "/home/curt/pmbootstrap/pmb/helpers/pmaports.py", line 133, in find
apkbuild = pmb.parse.apkbuild(args, path_current)
File "/home/curt/pmbootstrap/pmb/parse/_apkbuild.py", line 312, in apkbuild
"' in APKBUILD: " + path)
RuntimeError: Invalid pkgver '3.x.x' in APKBUILD: /home/curt/.local/var/pmbootstrap/cache_git/pmaports/device/linux-pin64-pinephone/APKBUILD
Everything went smoothly before the actual install attempt. Any suggestions will be appreciated.
(02-10-2020, 02:23 PM)curtvaughan Wrote: Hello. Here's what I get from the install to the sdcard:
build=False)
You typed pin64 instead of pine64 into the device selection when running "pmbootstrap init". so it created a new device page for that device with some scaffolding in it that isn't complete. to remove it delete "/home/curt/.local/var/pmbootstrap/cache_git/pmaports/device/linux-pin64-pinephone" and "/home/curt/.local/var/pmbootstrap/cache_git/pmaports/device/device-pin64-pinephone"
Then run pmbootstrap init again and type the correct name
#19
(02-07-2020, 08:57 AM)ksmithaz1 Wrote: From scratch on Ubu 18.04:
pip3 install pmbootstrap
PATH="$PATH:~/.local/bin"
mkdir ~/.local/var/pmbootstrap
pmbootstrap init
pmbootstrap install --sdcard /dev/sda
pmbootstrap shutdown
~20 min into install it prompts (after I'm in bed):
[21:13:57] (rootfs_pine64-pinephone) mkinitfs postmarketos-allwinner
[21:14:01]  *** SET LOGIN PASSWORD FOR: 'user' ***
New password:
Retype new password:
passwd: password updated successfully
[06:10:04] NOTE: No valid keymap specified for device
[06:10:08] *** (3/5) PREPARE INSTALL BLOCKDEVICE ***
[06:18:56] NOTE: chroot is still active (use 'pmbootstrap shutdown' as necessary)
[06:18:56] Done
So I selected kde + extras, set the password above to something simple ... pass1234
Boot it on the phone.  Sluggish, but it boots, play around breifly, plug in to charge.,  Now I have a lock screen, but it's only numbers, and I can't unlock the thing.
This is fun . . . Wink!  Not much on google search for a default.  Might have blown past it somewhere.  Probably should have started an installation thread.
try  Rob Braxmans install video on youtube , its not a "demo" flash, so will let you use all your "space" but you get the very latest phosh which may not have many apps, you can choose plasma, look for the advised inputs in  { parenthesis }  . good viewing for noobs ( like me)
#20
   build=False)
Thanks. Will try this out a.s.a.p.  Much appreciated.
  phone won't boot from emmc with sdcard inserted ssilvi 3 7,500 06-06-2021, 02:47 AM
Last Post: ssilvi
  Cannot boot from SDCard cube 2 6,287 01-31-2021, 11:47 AM
Last Post: cube
  pmbootstrap error lat 2 8,011 12-22-2020, 06:32 PM
Last Post: lat
  pmbootstrap issues IVp 3 10,409 09-24-2020, 02:24 AM
Last Post: Pinethom
  pmbootstrap build large keyboard not usable u20200719 5 12,107 07-25-2020, 02:31 PM
Last Post: u20200719
  Is it possible to pre-configure wifi and ssh with pmbootstrap? kelbot 2 8,921 07-06-2020, 01:55 AM
Last Post: ChriChri
  Dumb question: do I have to use pmbootstrap? quixote 5 11,550 06-11-2020, 09:23 AM
Last Post: plainenough
  pmbootstrap on Mac OSX srfne 2 11,195 02-29-2020, 04:15 PM
Last Post: srfne
  Does pmbootstrap install the latest image? mypine 4 11,811 02-20-2020, 01:02 PM
Last Post: mypine
  pmbootstrap - choose different ui after first run mypine 2 7,208 02-13-2020, 04:35 PM
Last Post: mypine
