Hi all, Ive found that .appimage does not work I'm trying to use cura.appimage but it does not work just like openscad.appimage is there any way to fix that maybe I'm missing something.. somebody having any luck with bouth programs ?
Cura OpenSCAD and .appimage
Are you using the default Debian build? Is this the Cura Appimage you're trying to get running?
01-16-2020, 03:18 PM
(01-16-2020, 08:39 AM)tophneal Wrote: Are you using the default Debian build? Is this the Cura Appimage you're trying to get running? yep I use default Debian build and yes thats the one and it runs great on my raspberry pie 4 also with default raspbian build.. But no luck with the pinebook
01-16-2020, 03:21 PM
Do you get any output if you try to open it using terminal?
01-16-2020, 04:01 PM
Users browsing this thread: 7 Guest(s)
