Kickstarter P64 with LCD, working image?
Hey all,
    I have a Pine64 from the kickstarter, I hope I am posting this in the right forum, I don't recall if it was considered a (+) version or not. I am trying to find an image that works with the LCD display. I much prefer a Ubuntu version, but I am not sure if there is one? I tried OpenSuse, but the OS simply doesn't seem to work. It won't update or install anything as it seems the site it is trying to connect to doesn't work anymore. I am hoping someone might be able to point me toward a Ubuntu (or really any distro that works, as I can't find *any*) image that works with the LCD panel.
Thanks!
-MH
Quote:I have a Pine64 from the kickstarter, I hope I am posting this in the right forum, I don't recall if it was considered a (+) version or not. I am trying to find an image that works with the LCD display. I much prefer a Ubuntu version, but I am not sure if there is one? I tried OpenSuse, but the OS simply doesn't seem to work. It won't update or install anything as it seems the site it is trying to connect to doesn't work anymore.
Pine64 makes hardware, while for software rather check this:
https://www.armbian.com/download/?tx_maker=pine64
For LCD support seek forum over there. If you seek for plug and play solution, you will not find one. Unless you use HDMI with standard resolution.
  Xenial Minimal Image (PINE A64(+)) 0.6.2-77 pineadmin 4 27,781 08-30-2020, 10:35 AM
Last Post: jrronimo
  Allwinner A64 RTC bug fix on bionic image? tkaivola 1 8,678 02-01-2019, 05:09 AM
  Ubuntu password not working joemassimino 4 14,479 05-18-2018, 03:33 PM
Last Post: Luke
  How can I get a wireless dongle working on Xenial Desktop latest build Rocklobster 1 6,939 04-16-2018, 03:09 PM
Last Post: Rocklobster
  Software Boutique- not working Partymack711 4 10,032 02-17-2018, 03:25 PM
Last Post: Partymack711
  (ARCHIVED) Ubuntu Xenial Image (BSP Kernel) longsleep 337 949,479 01-31-2018, 11:58 AM
Last Post: Luke
  Bluetooth not working reesh95 11 24,653 06-26-2017, 09:56 PM
Last Post: pfeerick
  Xenial Minimal Image (PINE A64(+)) 0.5.5-65 pineadmin 0 5,638 06-15-2017, 12:37 AM
Last Post: pineadmin
  Xenial Minimal Image (PINE A64(+)) 0.5.2-59 pineadmin 0 5,325 05-25-2017, 09:27 AM
  Facing difficulty in getting started with Ubuntu image nsisodiya 4 9,703 12-28-2016, 05:34 AM
Last Post: Luke
