Remote desktop client suggestions?
Sorry, it is
sudo snap connect remmina:gnome-3-26-1604 gnome-3-28-1804
(11-14-2019, 06:58 AM)mfritsche Wrote: Sorry, it is
thanks, it worked. Now I just need to figure out how to connect to my windows laptop.
Windows Home doesn't allow RDP'ing in (by license, it can be done though), and with Windows 10 Pro, you will need to configure windows to allow remote connections. Just type "remote" in the start menu, and the corresponding "allow remote access" (or similar) settings entry should come up.
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 2,025 02-16-2023, 10:58 AM
Last Post: cowsay
  Install the DDE desktop environment wangyukunshan 0 3,940 12-23-2021, 06:51 PM
Last Post: wangyukunshan
  Desktop environment of Ubuntukylin 20.04 wangyukunshan 3 7,680 10-26-2021, 08:07 PM
  No wifi icon on desktop and no connectivity motezart 0 4,383 11-16-2020, 12:52 PM
Last Post: motezart
  Deepin Desktop on PBP brent.thierens 11 20,645 10-29-2020, 10:02 AM
Last Post: Upokupo
  Signal Desktop Builds for Manjaro aarch64 ninefathom 25 50,154 10-23-2020, 02:19 PM
Last Post: llsf
  Is there a VOIP client compatible with aarch64? mjc 4 8,757 09-18-2020, 04:03 PM
Last Post: mjc
  Virtual Desktop Issues (Manjaro KDE) davemaps 1 5,476 08-31-2020, 07:28 PM
Last Post: brad2723
  pCloud Client on PBP w/ Manjaro? fbshilli 2 6,335 07-01-2020, 03:04 PM
Last Post: fbshilli
  Remote-viewer "Bus Error" wingmanjd 6 12,826 06-09-2020, 07:29 AM
Last Post: wingmanjd
