i3 and Lightdm
first I want to say thank you for this great piece of laptop. I received it yesterday and the hardware is really nice.
Only minor glitch is that it seems to be a bit light and so it's feet are lifted when the screen is fully opened. I think, I can attach a tiny weight and this would fix it.
BUT: Did anyone manage to change the session in lightdm? I tried to set user-session=i3 in lightdm.conf but it won't pick it up.
I also selected i3 from update-alternatives --config -x-window-managers, but also, no result. Even worse, my rock User won't login anymore.
What is the proper way to select the WM-Session in Debian? I never had any issues in Ubuntu. To I have to set something in the .xresource file?
In /var/lib/AccountsService/users det your file with session i3.
(10-25-2019, 02:05 AM)lispy Wrote: In /var/lib/AccountsService/users det your file with session i3.
Thanks for that. As you are doing the same thing as me on the same hardware, I am wondering if you came across this problem:
https://bugs.debian.org/cgi-bin/bugrepor...bug=918925
i3 is up and running, but I can't choose the font because of this veery odd bug, or so it seems.
I got it working by removing the "pango" part of "font pango" in the default config.
