What's the difference between board v2.2 and v2.3?
I got my new boards recently.
But I found the new one comes with v2.3
Just want to know what's the difference between v2.2 and v2.3?
Also, I found something interesting, when plugging the DC power,
my v2.3 board cannot boot all sopine module at the same time.
(Need try 2 ~ 3 times to bring all of them)
usually, 1 or 2 of them will stay off. (I use 50W DC power)
But v2.2 doesn't have such an issue. Any ideas?
Thx!
(06-23-2019, 11:11 PM)kazami2003 Wrote: Just want to know what's the difference between v2.2 and v2.3?
Sorry, no idea... I'll see if I can get an update for that... if there was any changes to the schematics that at least needs to be put up.
(06-23-2019, 11:11 PM)kazami2003 Wrote: my v2.3 board cannot boot all sopine module at the same time.
I don't seem to be suffering from that behaviour, but mine is a 2.2 also, running from the 5V dc terminals, with one of these 150W 24V -> 5v DC-DC step down modules (as I have 24V power running which it can tap into)... https://www.ebay.com.au/itm/DC-Voltage-R...2551055953
How do you determine they are not working? As I do notice occasionally the ethernet seems to drop out, or not work from boot, but the boards still boot up (I have a shell script that does a heartbeat flash on the GPIO led for the module once it boots, so even if it doesn't want to respond via ethernet I know it's actually up and running).
While I have problems on my own with the board, I noticed something in your post:
Quote:(I use 50W DC power)
I believe the recommended PSU from the Pine64 store is 5v 15A which makes it 75w.
Are you confident all modules receive sufficient power?
  Is my wooden desk a safe surface to test the cluster board on? ollehar 6 15,299 12-28-2020, 09:41 AM
Last Post: robocone
  Compatibility between RPi Module and Cluster board leperotero 1 6,196 11-03-2020, 03:40 PM
Last Post: poVoq
  What kind of box would be able to host both the cluster board and a RockPro64? ollehar 1 6,010 06-14-2020, 05:37 PM
  Just got my board ... Bazmundi 5 12,001 06-08-2020, 11:32 AM
Last Post: poVoq
