How to build Android P SDK
I found Android P SDK on Wiki.
Who was already downloaded and build it?
https://wiki.pine64.org/index.php/ROCKPr...ndroid_SDK
If someone tried it, i want to know how to build and burn to sd card.
(06-19-2019, 06:25 PM)licux Wrote: Hi,
Please follow this thread: https://forum.pine64.org/showthread.php?tid=7595
I was trying to build with the following config:
#!/bin/bash
ARCH=arm64
LUNCH=rk3399_box-userdebug
UBOOT_DEFCONFIG=rk3399
KERNEL_DEFCONFIG=rockchip_defconfig
KERNEL_DTS=rk3399-rockpro64
JOBS=4
And I get the following exception:
make[2]: Entering directory '/home/lineageos/external/rk_tee_user/ta/testapp'
/home/lineageos/prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc /home/lineageos/external/rk_tee_user/ta/testapp/testapp_ta.o
/home/lineageos/prebuilts/gcc/linux-x86/arm/arm-eabi-4.8/bin/arm-eabi-gcc /home/lineageos/external/rk_tee_user/ta/testapp/user_ta_header.o
CPP /home/lineageos/external/rk_tee_user/ta/testapp/ta.lds
LD /home/lineageos/external/rk_tee_user/ta/testapp/8cccf200-2450-11e4-abe20002a5d5c52c.elf
OBJDUMP /home/lineageos/external/rk_tee_user/ta/testapp/8cccf200-2450-11e4-abe20002a5d5c52c.dmp
OBJCOPY /home/lineageos/external/rk_tee_user/ta/testapp/8cccf200-2450-11e4-abe20002a5d5c52c.stripped.elf
SIGN /home/lineageos/external/rk_tee_user/ta/testapp/8cccf200-2450-11e4-abe20002a5d5c52c.ta
SIGN KEY /home/lineageos/external/rk_tee_user/export-user_ta/keys/oem_privkey.pem
Traceback (most recent call last):
File "/home/lineageos/external/rk_tee_user/export-user_ta/scripts/sign.py", line 80, in <module>
main()
File "/home/lineageos/external/rk_tee_user/export-user_ta/scripts/sign.py", line 40, in main
from Crypto.Signature import PKCS1_v1_5
ImportError: No module named Crypto.Signature
/home/lineageos/external/rk_tee_user/export-user_ta/mk/link.mk:65: recipe for target '/home/lineageos/external/rk_tee_user/ta/testapp/8cccf200-2450-11e4-abe20002a5d5c52c.ta' failed
make[2]: *** [/home/lineageos/external/rk_tee_user/ta/testapp/8cccf200-2450-11e4-abe20002a5d5c52c.ta] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: Leaving directory '/home/lineageos/external/rk_tee_user/ta/testapp'
Makefile:37: recipe for target 'ta' failed
make[1]: *** [ta] Error 2
make[1]: Leaving directory '/home/lineageos/external/rk_tee_user/ta'
Makefile:27: recipe for target 'ta' failed
make: *** [ta] Error 2
make: Leaving directory '/home/lineageos/external/rk_tee_user'
[ 2% 2330/92547] //external/f2fs-toolsConfusedload_f2fs clang fsck/xattr.c [linux_glibc]
ninja: build stopped: subcommand failed.
21:43:51 ninja failed with: exit status 1
Any ideas on what that would be?
Here are the steps I've followed:
Download SDK here:
copy build_box.sh from here to root directory:
https://github.com/a9rock64/rk_device_ro...ild_box.sh
Contents of build_box.sh
lineageos@ba44581f91b1:~$ cat build_box.sh
#!/bin/bash ARCH=arm64 LUNCH=rk3399_mid-userdebug UBOOT_DEFCONFIG=rk3399 KERNEL_DEFCONFIG=rockchip_defconfig KERNEL_DTS=rk3399-rockpro64 JOBS=4 usage() {     echo "USAGE: build [-ovj]"     echo "-o                    -Generate ota package"     echo "-v                    -Set build version name for output image folder"     echo "-j                    -Build jobs"     exit 1 } # check pass argument while getopts "ovj:" arg do     case $arg in         o)             echo "will build ota package"             BUILD_OTA=true             ;;         v)             BUILD_VERSION=$OPTARG             ;;         j)             JOBS=$OPTARG             ;;         ?)             usage ;;     esac done source device/rockchip/common/build_base.sh -a $ARCH -l $LUNCH -u $UBOOT_DEFCONFIG -k $KERNEL_DEFCONFIG -d $KERNEL_DTS -j $JOBS
In terminal in the base directory of the project do the following:
. build/envsetup.sh
./build_box.sh
I made a docker image with the required build environment dependencies:
https://cloud.docker.com/repository/dock...-rockpro64
The docker setup was borrowed from a lineage project and the instructions can be found here:
https://github.com/darran-kelinske-fives...-rockpro64
Had a successful build today:
Build android ok! make and copy android images TARGET_BOARD_PLATFORM=rk3399 TARGET_PRODUCT=rk3399_mid TARGET_HARDWARE=rk30board TARGET_BUILD_VARIANT=userdebug BOARD_SYSTEMIMAGE_PARTITION_SIZE=2684354560 BOARD_USE_SPARSE_SYSTEM_IMAGE=true TARGET_BASE_PARAMETER_IMAGE== HIGH_RELIABLE_RECOVERY_OTA=false BOARD_AVB_ENABLE=false system filesysystem is ext4 create dtbo.img.... BOARD_AVB_ENABLE is false,use default dtbo.imgdone. create boot.img.... BOARD_AVB_ENABLE is false, make boot.img from kernel. done. create recovery.img.... BOARD_AVB_ENABLE is false, make recovery.img from kernel && out. done. create system.img.... in=/home/lineageos/out/target/product/rk3399_mid/system.img out=/home/lineageos/out/target/product/rk3399_mid/system.img.out align=1024 Total of 655360 4096-byte output blocks in 22 input chunks. Generating optimized sparse image done,total_chunk=17. done. create vbmeta.img.... BOARD_AVB_ENABLE is false,use default vbmeta.imgdone. create vendor.img...in=/home/lineageos/out/target/product/rk3399_mid/vendor.img out=/home/lineageos/out/target/product/rk3399_mid/vendor.img.out align=1024 Total of 131072 4096-byte output blocks in 12 input chunks. Generating optimized sparse image done,total_chunk=8. done. create oem.img...in=/home/lineageos/out/target/product/rk3399_mid/oem.img out=/home/lineageos/out/target/product/rk3399_mid/oem.img.out align=1024 Total of 131072 4096-byte output blocks in 12 input chunks. Generating optimized sparse image done,total_chunk=8. done. create misc.img.... done. create uboot.img...done. create trust.img...done. create loader...done. create resource.img...done. create kernel.img...done. create parameter...done. Make image ok! Make update.img start to make update.img... Android Firmware Package Tool v1.62 ------ PACKAGE ------ Add file: ./package-file Add file: ./Image/MiniLoaderAll.bin Add file: ./Image/parameter.txt Add file: ./Image/trust.img Add file: ./Image/uboot.img Add file: ./Image/misc.img Add file: ./Image/boot.img Add file: ./Image/dtbo.img Add file: ./Image/vbmeta.img Add file: ./Image/recovery.img Add file: ./Image/system.img Add file: ./Image/vendor.img Add file: ./Image/oem.img Add CRC... Make firmware OK! ------ OK ------ ********RKImageMaker ver 1.63******** Generating new image, please wait... Writing head info... Writing boot file... Writing firmware... Generating MD5 data... MD5 data generated successfully! New image generated successfully! Making update.img OK. Make update image ok! /home/lineageos cwcw/home/lineageos /home/lineageos/IMAGE/RK3399-ROCKPRO64_9_20190718.1752_RELEASE_TEST/PATCHES/device/rockchip/rk3399/0001-set-lcd_density.patch Generate patch for device/rockchip/rk3399 done /home/lineageos/IMAGE/RK3399-ROCKPRO64_9_20190718.1752_RELEASE_TEST/PATCHES/hardware/rockchip/libgralloc/0001-close-AFBC_LAYER.patch Generate patch for hardware/rockchip/libgralloc done /home/lineageos/IMAGE/RK3399-ROCKPRO64_9_20190718.1752_RELEASE_TEST/PATCHES/kernel/0001-add-rockpro64-configs.patch /home/lineageos/IMAGE/RK3399-ROCKPRO64_9_20190718.1752_RELEASE_TEST/PATCHES/kernel/0002-for-tp-gt911-fw.patch /home/lineageos/IMAGE/RK3399-ROCKPRO64_9_20190718.1752_RELEASE_TEST/PATCHES/kernel/0003-generate-ethernet-MAC-address-form-cpuid.patch /home/lineageos/IMAGE/RK3399-ROCKPRO64_9_20190718.1752_RELEASE_TEST/PATCHES/kernel/0004-for-rockpro64-codec.patch /home/lineageos/IMAGE/RK3399-ROCKPRO64_9_20190718.1752_RELEASE_TEST/PATCHES/kernel/0005-add-sdcard-boot.patch /home/lineageos/IMAGE/RK3399-ROCKPRO64_9_20190718.1752_RELEASE_TEST/PATCHES/kernel/0006-set-boot_devices-sdhci.patch Generate patch for kernel done Generate patch for u-boot done /home/lineageos/IMAGE/RK3399-ROCKPRO64_9_20190718.1752_RELEASE_TEST/PATCHES/vendor/rockchip/common/0001-rk3399-vpu-use-mpp-for-mpeg2.patch Generate patch for vendor/rockchip/common done
  Android images for RockPro64 BitAnnihilator 5 18,372 06-04-2024, 11:05 PM
  Difficulty installing Android on Rockpro64 spammycheese 0 5,878 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 6,229 06-04-2022, 12:18 AM
Last Post: grobbs
  Slash TV Android for RockPro64 Wizzard 12 25,335 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 7,783 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 46,531 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 25,710 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 7,848 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 50,669 02-13-2021, 12:52 AM
Last Post: chisteven
  RockPro64 line out/headphones in Android 9 Wizzard 0 6,200 11-20-2020, 04:15 AM
Last Post: Wizzard
