mpph264enc output doesn't work on bionic
(05-16-2019, 09:39 AM)jonsmirl Wrote: That is 32b image. 32b is known to work. 64b is broken.
I believe 64b is broken because kernel and mpp aren't compiled using the same header files, so the IOTCL don't match between user space and the kernel.
So it still doesn't work on 64-bit? Are there any plans to support this in the future? Any idea if the new rock64pro works at all?
I guess that won't help, but I tried your commands with an OrangePi RK3399, and it seemed to work.
I suppose it is working with 32 bits, not 64...
$ sudo gst-launch-1.0 -e videotestsrc is-live=false num-buffers=500 \ > ! video/x-raw,format=NV12,width=1280,height=720 \ > ! mpph264enc ! filesink location=1280.h264 (gst-plugin-scanner:741): GLib-GObject-WARNING **: 09:29:09.504: cannot register existing type 'GstKMSSink' (gst-plugin-scanner:741): GLib-GObject-CRITICAL **: 09:29:09.504: g_type_add_interface_static: assertion 'G_TYPE_IS_INSTANTIATABLE (instance_type)' failed (gst-plugin-scanner:741): GLib-GObject-CRITICAL **: 09:29:09.504: g_type_add_interface_static: assertion 'G_TYPE_IS_INSTANTIATABLE (instance_type)' failed (gst-plugin-scanner:741): GLib-CRITICAL **: 09:29:09.504: g_once_init_leave: assertion 'result != 0' failed (gst-plugin-scanner:741): GStreamer-CRITICAL **: 09:29:09.504: gst_element_register: assertion 'g_type_is_a (type, GST_TYPE_ELEMENT)' failed Setting pipeline to PAUSED ... mpi: mpp version: b212d1b author: Jacob Chen [mpp]: fix mjpeg buffer leak Pipeline is PREROLLING ... h264e_api: h264e_config MPP_ENC_SET_RC_CFG bps 3456000 [3240000 : 3672000] Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock Got EOS from element "pipeline0". Execution ended after 0:00:14.428808048 Setting pipeline to PAUSED ... Setting pipeline to READY ... Setting pipeline to NULL ... mpp_thread: MPP_THREAD_STOPPING status set mThread 0xab2a1c30 Freeing pipeline ... linaro@captation-techforum-rk3399-4GB:~$ ffprobe -hide_banner 1280.h264 Input #0, h264, from '1280.h264':  Duration: N/A, bitrate: N/A    Stream #0:0: Video: h264 (High), yuv420p(progressive), 1280x720, 30 fps, 30 tbr, 1200k tbn, 60 tbc
  A/V output enable 8lall0 0 1,443 03-24-2026, 04:45 PM
Last Post: 8lall0
  Rock64 v2 - did not work song / audio sqw200zu 2 6,685 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  HDMI doesn't work on rock64 Noung1991 1 4,266 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 14,283 06-30-2022, 06:28 PM
Last Post: rookie_267
  armbian / bionic - hdmi to vga not functioning on newer5.4 kapqa 1 5,645 03-31-2020, 07:19 PM
Sad HDMI doesn't work on rock64 rock7 0 4,964 12-16-2019, 01:04 PM
Last Post: rock7
  Owncloud installation on Ubuntu Bionic Count Omega 9 19,438 07-19-2019, 03:54 AM
Last Post: stuartiannaylor
  HDMI output with Arch Linux Arm yogo1212 2 8,080 07-17-2019, 02:46 AM
Last Post: yogo1212
  Screen lock fail Bionic-lxde-rock64-0.7.8-1061-arm64 electrique 0 3,759 12-28-2018, 11:00 PM
Last Post: electrique
  bionic lxde 0.6.xx was not getting audio/sound jose_s_c 2 7,130 11-13-2018, 11:18 AM
Last Post: UnicornFarts
