disappearing sata drives
I'm running the latest Ayufan openmediavault image and had set debain to update with the testing channel (I need samba time machine support and my understanding is you should never mix stable and testing.). The drives keep disappearing.
I know there's a lot of variables here but where should I start when trying to figure out this problem?
This is probably the issue you face:
https://forum.pine64.org/showthread.php?tid=6932
I have the beefiest power supply from pine so that’s not likely it. It’s been running okay for a while but I doubt it will stay. There are a lot of complaints online about this specific controller so I might need to get a different card.
Question nand-sata-install on RAID-1 array ARMandHammer 1 3,748 02-12-2023, 03:10 AM
Last Post: igorp
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 13,880 05-20-2021, 10:04 PM
Last Post: t4_4t
  Upgrade Debian kernel on a SD/SATA drive boot combo. linuxha 6 14,381 12-12-2019, 04:43 AM
Last Post: dukla2000
  PCIe Sata II adapter and ssd TRIM bavay 0 3,204 08-16-2019, 07:49 AM
Last Post: bavay
  Marvell 88SE9235 PCI SATA card in LibreELEC StefanRvO 6 13,000 05-18-2019, 04:21 AM
Last Post: p1x3l3d
  Image for ZFS on PCIe SATA drives with OpenVPN and WiFi caillou 0 3,678 02-26-2019, 05:14 PM
Last Post: caillou
  Sata/PCI-E problems? Takenover83 6 13,113 10-20-2018, 05:36 AM
Last Post: jja2000
Information PCIe -> SATA and NVMe work as of 0.6.59 Luke 13 25,685 08-06-2018, 11:33 AM
